#26 |
STILL PLAYS WITH TRUX
Heres your options
1. Cut your losses and pull that POS out of the frame rail's while the thing is half torn down ![]() 2. Reassemble that POS using all the old gaskets and fire it up with a large brick sitting on top of the happy peddle and wait for that sweet sound of a POS 305 going Boom! ![]() 3. Get a A/C Delco crate Eng. and be done with it there's one for every budget it dont have to be a high output one! a stock 350 is good cuz it's a 350 then you can do pwr add on as money allows ![]() Last edited by 87 STEPPER; 02-14-2006 at 01:22 PM. |
#27 |
Re: Just found out my 350 is a 305 :( What would you do?
I'd slap the 305 back together and run it till it dies. While you're running the 305, you can buy a used 350 and build it on the stand as time/money permit.
#28 |
Hotwheels?
Yep, I did play with the idea of rebuilding an old 350, I actually had one for a while, but I got rid of it. For the value of my time and money, Goodwrench it is. and like what was said earlier, an Comp cam will give it about 300 hp or so with nothing else touched.
1978 Money Pit - CUSTOM DELUXE!!!! |
#29 |
Too bad you are so far away . I have a 350 from an 83 3/4 ton in my way . Good luck with what ever you decide . I had a 305 in my truck in high school with a large cam ,carb,and intake . It was a dog until it got wound up . I ran the snot out of it until I finally spun a couple rod bearings . Frank
Born and proudly residing in a Red State ! |
#30 |
I'm in the market for a 350. Was looking at the GMPP 290HP. f.monroe, I would like some details on that 350 if you could send me a PM. I live up in North Texas.
#31 |
PROUD TO BE A MEMBER
Wondering out loud ,you upset over the engine size or the fact you bought the nascar story, The simple fact is people going to lie to you the rest of your life ,if you catch on now learn from it now, maybe you should go thank the guy,cause it sure was a cheap lesson
just a thought good luck |
#32 |
I once bought a mustang the guy swore it had been punched out .030 and had portef heads, a few months later when I tore it down(cuz it went boom lol) not only was it all stock but the rods were all mismatched like the motor had been thrown together. I bought it cheap enough but still was pissed the dude lied. As far as your bowtie block goes spend your money on nitrous. I only read the last few replies so I didn't even see what your drivin but screw it pump about a 150 shot into that smogged 305 until it poops rods on the hiway and then get yer 350. Then you've already got the NOS
85 Chevy 1/2 ton Extended cab conversion. http://i19.photobucket.com/albums/b1.../trucks014.jpg http://i19.photobucket.com/albums/b1.../trucks031.jpg http://i19.photobucket.com/albums/b1.../trucks032.jpg |
#33 |
I'm back with 2nd truck!
I would sell the 305 and the parts that you can't use on the crate engine. This will help counter any $$$ you're out. Definately stick with a crate engine from GM 36K mile warranty and all brand new parts, nothing rebuilt.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
#34 | |
#35 | |
actually 79big10, GM "upped" there warranty on that base 350 motor...it now has a 3 yr 100k mile warranty!...no $hit....cant beat that with a stick ![]()
1987 350 TBI lowered 5/7 |
#36 | |
I have to admit that I'm still looking to start with how much you really have to spend - based on that I think you'd get a crisper message on good options. I don't know that $1300 for a low compression iron motor is the best deal on the planet - or all that upgradeable - but if you just want to do a drop and go I agree it's the shortest trip. If you're looking for cheap, I'm still not clear why you wouldn't just do a cheapie overhaul on the 305. If you don't want to put $$$ into the admittdly crud 305 heads then buy some good aftermarket ones and figure you'll swap them to a GOOD 350 when you get some add'l cash. Sounds like you've made a choice; good luck and let us know how it works out! |
#37 |
![]() Join Date: Apr 2005
It does cost more to rebuild a 305 compared to a 350. The other thing to is the same heads you use to make compression on a 305 probably wouldn't allow pump gas friendly compression in a 350 setup. It sounds to me that he would be happy with a goodwrench350. It's a hard deal to beat for a daily driver. If you wait and save up for the 350 H.0. that G.M. offers you could have the best of both worlds with performance(330hp-380tq) and reliability.
#38 | |
Hotwheels?
#39 | |
#40 | |
#41 | |
Insert Witty Text Here
Slonaker |
#42 | |
http://chevyhiperformance.com/tech/e...ne/index1.html Make sure you read the small print: - manual transmission - "350ci small-block awaited an overhaul" - no idea what the CR is - World Products SR heads - hydraulic flat-tappet, single-pattern Lunati camshaft (0.507 lift) Veerrrry different engine all through. I can tell I'm flogging a dead horse here. ![]() I guess my point is that for $1300 you get an engine that you won't keep anything but the block and rods from if you build it up. And if power doesn't matter you could drop that into some decent heads and a cam for the 305 and get around the same numbers per my previous post. |
#43 | |
I guess I don't see this as an apples-to-apples comparison. |
#44 |
I found the article I think - the "Goodwrench Quest"?
I didn't see any $$$ for anything - is it later in the article? 290 HP was with head porting and a full valvetrain swap - the Comp Cams kit (with springs) was about $410, and I have to expect that the head work was AT LEAST $500 (backcut alone is ~350). So there's a crisp grand on top of the "crate" =:-* for 51 HP (239 -> 290)? |
#45 |
Stylin
just my 2 cents but id love to have my 305 back. i replaced my 305 with a crate 350 from scoggin dickeys im not doggin them there great but my 305 had flat top pistons and a rv cam in it and pulled a little more with little bit better gas mileage.
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
#46 |
![]() Join Date: Apr 2004
Call these guys. They can set you up. I was happy with the motor I bought from them. turn the sound down on your computer before you clink the link, they have crappy music playing on the web site.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#47 | |
You're right. He bought the GM crate engine and wasn't happy after some time. Then swapped the factory heads and cam for Edelbrock aluminum heads and Comp Cams XE268 cam then added a Edelbrock aluminum intake. Same bottom end with the pistons, cranks rods, but just built up the top end to help out on the HP. Easily to upgrade these engines from the factory with the right combination of parts to work together.
#48 | |
#49 | |
Hotwheels?
#50 |
I'm not "fighting" anything - just trying to share information. You asked, but I'll stop
