07-25-2002, 01:28 AM | #26 |
Early Classic 1/3 drop coils
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
07-25-2002, 01:42 AM | #27 |
Bigvinnie thats one low 1/3 drop, are those really tall tires?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
07-25-2002, 01:45 AM | #28 |
mine is dropped like 6/5 or 5.5/6, bought it this way, its got quite a bit of rake, need a c-notch before i can go lower
front drop spindles - not sure either 3" or 2.5" front coils - i believe theyre just chopped orig coils yes front has negative camber despite the **** load of shims on the upper control arm. this is probably the reason no one suggests going lower than 5' up front without bags. rear 1.5" blocks 3.5" eibach coils i believe. adjustable tracking bar doestch tech shocks all around, despite the cut coils up front and major slam up front, the truck rides like a cadillac, rides better than my 01 blazer did stock, go figure |
07-25-2002, 01:48 AM | #29 |
another shot. someday ill have my truck as low as XXL and slammed67
07-25-2002, 02:50 AM | #30 |
bags!!!!
07-25-2002, 10:24 AM | #31 | |
Seņor Member
What size tire/wheel have you got on the front?? Kenneth
07-25-2002, 11:43 AM | #32 | |
Hot Rods For Life
07-25-2002, 12:46 PM | #33 |
Cowboy Fan for Life!!!!!!
383Stroker- What are those things across the front of your hood????....JB
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
07-25-2002, 03:58 PM | #34 |
Bamm 24, those are DZUS Fasteners. They hold the fiberglass hood on the truck.
07-25-2002, 05:27 PM | #35 |
THis is what mine will look like soon
07-25-2002, 07:48 PM | #36 |
As a matter of fact . . . it's possible I might be selling either the original frame from my 67 or the extra unrestored straight 67gmc/leaf rolling chassis I recently acquired. My original frame has been stripped/sand-blasted, primed w/DP90 epoxy primer; the trailing arm crossmember has been boxed w/5" holes punched for exhaust clearance; trailing arms welded+ new relocated shock mounts(frame is currently set-up for coilovers & some welding was done after priming so it needs repriming).
My goal when purchasing the gmc frame was to incorporate all the changes I've done to the original frame all @ once for a cleaner/more professional look on a fresh frame & switch to a 4-link to resolve trailing arm to frame clearance issues for the ride height I want. But I've been busy @ work & @ my buddies part-time shop they've been tied-up w/a chassis car resulting in the gmc frame just sitting in the driveway on the trailer( I'm sure the neighbors would like to see it go). I will make a decision by end of Aug. Undecided on any pricing @ this time though.
08-19-2002, 10:18 PM | #37 |
My 01'
http://www.dfwstangs.net/hosting/BAD.../badasssig.jpg 74' Camaro SBC/TH350 Thats all you need to know. Want some?...Come get some! |
08-19-2002, 10:52 PM | #38 |
3.5-5.5 ECE dropped spindes and springs.
72 Chevy SWB |
08-20-2002, 12:10 AM | #39 |
Location: Katy, TX...but the love of my life resides in Dublin,OH.
DONE WRONG
PO I guess did this. Heated the springs and roasted the ride... but I do like the stance... I will try and get close when I do the frame off starting very soon.
08-20-2002, 12:49 AM | #40 |
SLICER AND DICIER
XXL, HACK ON BROTHA!!! LOL I was in the same boat, my truck sits on the arch you spoke of, so I bought the much needed NEW FENDERS and started CUTTIN. hehe. I notched them all the way up to the hood hinges. I had to make room for bigger plans, I sold the 17's in the pic and got my 20's and 22's ordered. HELL YEA!!
01 Tahoe 22's 2/4 drop and tv's 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
12-10-2006, 08:47 PM | #41 |
Re: Can you please post pics of your lowered '67-72?
i just lowered my '72 with shocks and classic springs .ended up being about 2 and 4 from where it was. i have 1973 buick 455 from gs riv n it . execpt for a performer intake ,oil pump kit and a holley its all stock . i got an adatper to mate up to the original chevy 4 speed , using a centerforce dual friction clutch . i have a sweet cab( a/c auto ) and front clip from a well stored 35,000 mile camper , and most of another rust free box including fenderr hanging in my office , not to mention all the parts ive botten new . hopefully i will tear into it this spring . may be goin to a 400 turbo , only cause the other cab has the hump welded and the column is sweet . those are 8 inch cragar wheels with 255 /70 -15's
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car Last edited by 66skylarkpost; 12-10-2006 at 08:51 PM. |
12-10-2006, 09:00 PM | #42 |
yes i said buick 455
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
12-10-2006, 09:57 PM | #43 |
I have two inch drop spindles with lower springs. Hope these help! look at LMC under the lowering kits, it has some pretty good pics of how they'll look.
12-10-2006, 09:59 PM | #44 |
sufficiently talented fool
Here is mine. 3/5 drop done with springs 255/50zr17 front and 255/60vr17rear. Impala SS rims.
Attachment 229801
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board Last edited by centsless; 10-04-2007 at 08:52 PM. |
12-10-2006, 10:10 PM | #45 |
Bags . Notched in back. Front z'd .
12-10-2006, 11:04 PM | #46 |
I would be interested in your exact drop combo, this is how I would like my 70 to sit....infact I have the SAME wheels coming, just not chrome!
1970 Chevy C 10 SWB |
12-10-2006, 11:48 PM | #47 |
where are the lwb :P
12-11-2006, 12:33 AM | #48 |
Lowered 2" and 4"
12-11-2006, 12:39 AM | #49 |
12-11-2006, 10:05 AM | #50 |
Here's the old mule!
I have a 4.5/5 drop. Front: ECE 2.5 inch drop spindles and 2 inch drop springs. 20x8.5 Bonspeed Malibus with 5 inch BS on Yokohama Parada Spec-X 255/45-20. Rear: ECE 5 inch drop springs. 20x10 Bonspeed Malibus with 5.5 inch BS on Yokohama Parada Spec-X 295/45-20.
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) |
