Old 03-19-2006, 06:09 PM   #26
powell72
powell72's Avatar
Re: Trim or no Trim
Stock or resto-rod, trim. Full on custom, no trim. Year doesn't matter.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 03-19-2006, 07:22 PM   #27
john8746
john8746's Avatar
Re: Trim or no Trim
no trim
C/10 John N.J.
john8746 is offline   Reply With Quote
Old 03-20-2006, 06:03 PM   #28
49studebaker
49studebaker's Avatar
Re: Trim or no Trim
I'm building a daily driver, not a show truck, so I'll most likely go with trim on the bottom and pinstripe on the top. I would do a show truck differently but besides a mild drop and shortened frame, this will be somewhat stock.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 03-20-2006, 06:25 PM   #29
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Trim or no Trim
Originally Posted by matthufham
67, no trim single color
68, do the 50th anniversary paint job
69-70, no trim single color
71-72, 2 tone paint with full trim.
I agree with this, whole heartedly.
On my '69, which came new with the upper and lower side trim, I plan to remove both. If forced to have any trim on it, I'd prefer the '68 trim, even though I have a '69. But, I won't remove one type, to install another. Instead, I'll just pull it all, fill the holes and go on with my painting plan.
Member Nr. 2770
Old 03-20-2006, 07:21 PM   #30
cstanley
cstanley's Avatar
Re: Trim or no Trim
Originally Posted by 1969k10stepside
Which choice do you like better.The clean smooth sides without trim or
new expensive trim on them.
loaded question...
you might as well ask: Do you like the sweet, smooth look without trim, or do you like the junky, clunky, crappy look of trim?
if you're trying to make a decision, it sounds like you've already made it. if you're just asking, that's different. it's a lot easier for beat up trim to make a truck look bad than one without trim. for it to really look good with trim, the trim has to be in very good shape.
i like trim for a resto, smooth for custom. until the trim gets wrapped up in the spinning brushes of an automatic car wash (damned speedy wash...)
cstanley is offline   Reply With Quote
Old 03-20-2006, 07:31 PM   #31
JAKES 68GMC
Aluminum slot wheels rule...
Re: Trim or no Trim
No trim at all. After awhile it will sag down and become misaligned, and if your going to use your 4x4 as a 4x4, then no doubt your trim will become out of place.
JAKES 68GMC is offline   Reply With Quote
Old 03-20-2006, 07:34 PM   #32
1969k10stepside
Re: Trim or no Trim
The problem is after i spend thousands of dollars in stuff for it i might be afraid to get it off the road.
1969k10stepside is offline   Reply With Quote
Old 03-20-2006, 07:39 PM   #33
Ironhorse
Ironhorse's Avatar
Re: Trim or no Trim
Here's a pic of my stock height '71 4x4. Came with the lower trim but after looking at trying to find affordable upper and lower trim decent enough to go with new paint I decided to remove the trim completly. Consider it a daily drivr except for the gas mileage.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 03-20-2006, 10:58 PM   #34
bluragtop
New Member
bluragtop's Avatar
Re: Trim or no Trim
I am going with no trim on mine. When I stripped off the trim I found lots of rust hiding behind it.
bluragtop is offline   Reply With Quote
Old 03-20-2006, 11:07 PM   #35
Musclerodz
Re: Trim or no Trim
2 tone, trim it. Otherwise, no trim. I am removing all the trim from my Blazer and I had NOS pieces to put back on it.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
