Old 10-17-2006, 12:07 AM   #26
Musclerodz
Re: 6 lug rear disc install done!
Originally Posted by RunTMCfan View Post
Ok I'm kind of a brake Newbee. Should you upgrade the front discs to keep up with the very efficient technology of the new rears?
Also, are these ABS. I can lock up my front discs on my 72' with no sweat.
Fronts are next. They are also off '03 burb.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 10-17-2006, 12:30 AM   #27
Musclerodz
Yes, these brakes will require 17" or larger which is what I had planned from the start. Burbs are stock rear disc even of the '06 and '07 models. Trying to make this stuff work I found a rear disc brake option code JL2 for pickups. Here are a few part numbers:
Disc brakes: don't know, got them off car-part brand new 2003 Suburban
$209.00 with shipping
e-brake cables: 15087072 $39.95
15087071 $29.95
brake hose with bracket (would have bought stainless braided hoses but need the bracket that holds the hose and only serviced with the hose for some reason) : 21999529 $39.73
21999528 $39.91
clip (holds the RH e-brake cable and hard brake line on top of the pumkin):
15206266 $ 3.64
guide (on '06 JL2 trucks, hold the e-brake cables freely so they can move with the suspension):
15258706 $ 8.43
15221823 $ 1.71
Total parts to date : $379.79
Still have to come up with a custom hardline and figure out how to make the e-brake cable work, but that will all come one I get the rear end built and installed which is what I am working on now. Unfortunately progress has been slow the last few months and I am hoping that will change over the winter.
Mike
Mike Redpath
Old 10-17-2006, 02:02 AM   #28
ghetto_superman
ghetto_superman's Avatar
SWEET SWEET deal man! IIRC you have dual piston calipers on the rear.. ive got a set of single pistons (disc conversion kit w/ lowered spindles from brothers trucks) for my front already... and the question is.. would it be dumb to have singles in the front and doubles in the rear? would the 'correct' thing be to have them match?
ghetto_superman is offline   Reply With Quote
Old 10-18-2006, 02:11 AM   #29
Musclerodz
I am putting the '03 brakes up front as well so they will match when done. What I forgot to mention above is that I had to machine the center of the rotors out to clear the large bore. Luckily I have a good friend who is a machinist.
It would be best if they matched, but you could run an adjustable proportioning valve to tune the balance on the brakes which I will be doing. The larger brakes serve a saftey issue most people ignore when installing bling wheels (22" and larger) or 40" off road tires. All that extra rotating mass requires larger binders to stop as effectively as the stock stuff stopped original equipment. I will be running 18" wheels and 33" tall Nitto tires.
Mike
Mike Redpath
Old 10-18-2006, 02:30 AM   #30
ghetto_superman
ok i gotcha. so now when you say you had to machine out the rotors, do you mean the area that appears to be the e brake 'drum'? or just the hole in the face of the rotor that the axle hub pops through?
Old 10-18-2006, 02:33 AM   #31
Musclerodz
The center hole of the rotor that fits over the axle hub.
Mike
Mike Redpath
Old 10-18-2006, 02:46 AM   #32
ghetto_superman
ok so i m guessing you put the old axles into the new narrowed rearend? (sorry for all the q's but im hooked!)
Old 10-18-2006, 06:31 PM   #33
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by Musclerodz View Post
Finally got the rear calipers in. Man, these are huge. It will require a 16" wheel minimum to run these brakes.
Mike
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-19-2006, 12:26 AM   #34
Musclerodz
No, original rear end with new axle flanges in the same location.
Mike
Mike Redpath
