Old 05-10-2006, 09:24 PM   #26
perrosinpata@aol.com
perrosinpata@aol.com's Avatar
Re: Progress pics - air system, not far...yet
Thanks for the info.Goodluck!
perrosinpata@aol.com is offline   Reply With Quote
Old 05-10-2006, 10:58 PM   #27
71swb4x4
71swb4x4's Avatar
More progress tonight. I was able to drill the holes in the crossmember for the bulkheads.
The first two pictures are of the driver's side, I haven't finished this side yet.
The second two pictures are the passenger's side, I was able to get both of these fittings in tonight.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-10-2006, 10:59 PM   #28
71swb4x4
71swb4x4's Avatar
Here are the emergency fills for the individual bags. I have it set up so I can fill the air tanks with a schraeder valve, or I can fill each individual bag with a schraeder valve.
Old 06-08-2006, 10:59 AM   #29
smbrouss70
smbrouss70's Avatar
Anymore progress?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 06-08-2006, 01:42 PM   #30
71swb4x4
71swb4x4's Avatar
Front bags are in, I still have to run the lines to the front bags, wire the system, and run the lines to the gauges. I haven't gotten to spend much time out there, but I am getting close. I will put some new pictures up this weekend.
Old 06-09-2006, 11:57 AM   #31
Hart_Rod
Hart_Rod's Avatar
Where did you get the bulk head fittings? Do you have a part #? I want to use something similar on my front crossmember. Thanks,
Rob
Hart_Rod is offline   Reply With Quote
Old 06-09-2006, 01:43 PM   #32
71swb4x4
71swb4x4's Avatar
Rob
I ordered all of my fittings from the same place, I will get you the information tonight.
Old 06-18-2006, 11:40 PM   #33
hotrodhomi
hotrodhomi's Avatar
Can I get this info too?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 06-18-2006, 11:46 PM   #34
71swb4x4
71swb4x4's Avatar
www.hoseandfittings.com
Funny you posted tonight, I was going to update this old thread.
I had play with the crossmember bulkhead fittings, I cut some pipe at an angle so I could get the fitting to point at the bag a little straighter. I have everything plumbed now. Sometime next week I hope to pressurize the system so I can start chasing down any leaks that I may have.
I still have to try to figure out how to mount my York compressor to the passenger side.
I also have to finish the wiring.
Slowly but surely!
Old 06-19-2006, 12:17 AM   #35
hotrodhomi
hotrodhomi's Avatar
let me know how you mount your york. Mine is still sitting in the box.
'66 impala ht
Old 06-19-2006, 06:46 AM   #36
68C15
blood type; Retumbo
68C15's Avatar
hey Shawn, if you have an extra york bring it down and I can fab up some brackets for ya. I'll use Lefty as a pattern.
68C15 is offline   Reply With Quote
Old 09-11-2006, 05:13 AM   #37
gringoloco
A guy with a truck
gringoloco's Avatar
Get anywhere with the York yet? Tossin' around ideas of an EDC too...
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-11-2006, 12:10 PM   #38
jimmydean
jimmydean's Avatar
Using conduit is a great idea! I might need to do that. I don't understand why you ran a bulkhead fitting for the crossmember though. Looking at the install diagram I have, they just ran a hose from the bag to the valve.
I am still waiting for my brackets and drop spindles, then I can do mine! Nice work.
jimmydean is offline   Reply With Quote
Old 09-11-2006, 12:56 PM   #39
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I didn't see where bulkhead ftgs were necessary either. I just used a 90* fitting, 1/2" NPT x 3/8" DOT push-to-connect. It also swivels which makes it nice. Once you tighten the fitting into the bag, you can still swivel the 90 to where you need to run the line. It was a piece of cake. It was a little difficult to get my hand in there to push the line into the fitting, but once I got it in there I was good to go.
I also can't see why you needed to cut holes in the floor to get to the upper bag mounts in the rear. Granted I've got a P/U but I didn't even remove the bed to mount the bags and plumb everything. The hardest part was drilling the 1" hole for the fitting on the bag port to clear through the frame. Again, here I used a 90* fitting just like on the front and then ran the line down the frame to the rear valves. I can't imagine that the Blazer frame back there would be that much different, is it?
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 09-11-2006, 01:20 PM   #40
71swb4x4
71swb4x4's Avatar
-Chris
I have a boardmember working on brackets. I haven't gotten anywhere so I haven't bugged him about them.
I will take another look at it. If I can cleanly run the lines without them rubbing anywhere I may get rid of the bulkheads, the less fittings the better.
I couldn't get me hand up in there to bolt the bags in. The bolts where spaced far enough apart that one was really close to the frame and the other close to the cup. Since there was already a huge hole in the floor cut by the PO I decided to go that route. If I could have had my truck on a lift I think I could have gotten by without cutting the holes.
Old 09-11-2006, 02:01 PM   #41
jimmydean
jimmydean's Avatar
<stuff>
I was planning on using the 90 degree swivel as well. I also think I will use the metal conduit for looks and durability. I would rather not have to buy any more fittings. I'm $140 into fittings as it is.
Old 09-11-2006, 04:28 PM   #42
hotrodhomi
hotrodhomi's Avatar
Does this board member want to make another one?
'66 impala ht
Old 09-11-2006, 11:06 PM   #43
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
this is the place I will use if I go that route EDC
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 09-12-2006, 12:42 AM   #44
hotrodhomi
hotrodhomi's Avatar
Why would this only work for a long style water pump?
'66 impala ht
Old 09-12-2006, 06:49 AM   #45
gringoloco
A guy with a truck
gringoloco's Avatar
Pulleys are in a different position fore/aft about 3/4" with the different w/p set-ups.
Looks like a bolt on solution for some. Too bad I have a supercharger sitting right there...
-Chris
Old 09-12-2006, 11:02 AM   #46
hotrodhomi
hotrodhomi's Avatar
how do I know if I have a long water pump?
'66 impala ht
Old 09-13-2006, 04:17 AM   #47
gringoloco
A guy with a truck
gringoloco's Avatar
Look between the back of it and the timing chain cover; if there is a 3/4" gap, you have long accessories. If the pump is resting on the cover, you have short.
-Chris
-Chris
Old 09-13-2006, 11:04 AM   #48
hotrodhomi
hotrodhomi's Avatar
THanks gringo.
Camaro_thunder- I tried to contact your bracket supplier, but had zero luck. I did some research and found that he doens't make these anymore. Any other ideas?
'66 impala ht
Old 09-14-2006, 01:21 AM   #49
gringoloco
A guy with a truck
gringoloco's Avatar
Any other ideas?
May be able to do something with this:
http://www.easystreetair.com/browsep...r-Bracket.HTML
Some assembly required...
-Chris
Old 09-14-2006, 01:44 AM   #50
hotrodhomi
hotrodhomi's Avatar
thats funny, who would buy this? If you have to make the bracket yourself why couldn't you drill the holes?
'66 impala ht
