Old 04-29-2006, 10:17 AM   #26
makovai
makovai's Avatar
Re: tire fitment help
antoher consideration is rim width. If you go with a really wide wheel, like maybe even a 12" you can get a taller tire under less lift. I had 35x12.5 on 8" and now run 36x14.5 on 10" and the truck sits the same as it did with the 35s although different tire measure diffently.
another thought is i had 32x16 eagles on my dragcar, changed to M/T 32x16.5 and the m/t are rediculously narrower although the size is bigger.
Goodyear measure across the tread and M/T measure acoss the buldge. and they are about 1.5 is shorter on the same wheel.
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
