Old 12-17-2006, 09:19 PM   #26
poorboy
poorboy's Avatar
Re: Fast Orange: Rodstoration
The truck has come along way. Keep up the good work.
poorboy is offline   Reply With Quote
Old 12-17-2006, 09:30 PM   #27
Rollie396
someday it will be done!
Rollie396's Avatar
jeez man you're catchin up to me in a big hurry!Lookin great so far.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 12-17-2006, 10:19 PM   #28
CPNEJR
CPNEJR's Avatar
lots of progress getting done there. now come to my garage and do some work on mine so i can have it when i get my drivers license
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 12-18-2006, 08:12 PM   #29
pimperout
pimperout's Avatar
i like that a lot man good job
pimperout is offline   Reply With Quote
Old 12-24-2006, 06:10 PM   #30
fnoblitt
fnoblitt's Avatar
i am going to be doing the same thing to my 70. what did you use to cut the floor with ? and what brans/amp welder did you use ? your doing a grewat job.
70 c10 stepside ,350v8, m-20 4 speed
fnoblitt is offline   Reply With Quote
Old 12-24-2006, 06:49 PM   #31
my67C10
my67C10's Avatar
where did you get the instrument cluster and glove box cover? i really like thoes!
my67C10 is offline   Reply With Quote
Old 12-24-2006, 07:00 PM   #32
QKENUF4U
QKENUF4U's Avatar
hopefully ya threaded the nut onto the short end of your balancer installer truck is looking good, im jealous
QKENUF4U is offline   Reply With Quote
Old 12-25-2006, 12:34 AM   #33
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Progress is coming fast! You are about as far along as I am and I have been at it for 4 years now! Thanks for the pics and keep 'em coming. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-25-2006, 08:38 AM   #34
jay6891
Car Knocker
jay6891's Avatar
To keep your fingers from getting all nasty from spreading seam sealer with them. Dip your finger in thinner before you start and keep dipping as you work and it will not stick. The trick is to keep your fingers wet with thinner. Body man showed me that.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 12-28-2006, 12:10 AM   #35
mhdie
great work! keep us updated 88
mhdie is offline   Reply With Quote
Old 12-28-2006, 12:32 AM   #36
jay-dawg
chevelito
jay-dawg's Avatar
progress looks good!
Jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 12-31-2006, 01:04 AM   #37
muddpile
muddpile's Avatar
Thanks guys! Lots of new progress, but I need to charge my camera. Here's some answers to your questions:
Fnoblitt: I used a variety of things. Everything from a sawzall with a metal blade, to an angle grinder with a thin wheel to a dremel with a 1 1/2 cutoff wheel. Whatever fit the area the best. The Welder I use is a Hobart Handler 140 gas mig.
my67C10: I actually built the instrument cluster. I just took a stock 3 hole unit from the wrecker, removed the gauges, cut all the bracing off the back, sanded the front smooth and fibreglassed the holes shut. I then cut new gauge holes with a holesaw, textured it using SEM texture paint, airbrushed a pile of skulls on it and cleared it. Took a few nights, but I ended up with something functional, and totally unique. The glovebox door is a stocker that got the same treatment of texture and skulls.
Jay6891: Thanks for the tip. I'll be using more of it later next week, and I'll be sure to try that.
muddpile is offline   Reply With Quote
Old 12-31-2006, 10:20 AM   #38
Yukon Jack
Post Whore
Yukon Jack's Avatar
Lot of work happening on that one. Keep at it!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-31-2006, 02:58 PM   #39
muddpile
muddpile's Avatar
More progress pictures. These aren't the most current, but within the next few days we should be right up to date. The cab corners are just about finished, and the rockers will be in shortly as well. The doors took a bit of tweaking, but they ended up fitting pretty well.
I have finally decided to get rid of my in-cab tank. I bought this patch panel off Ebay for about ten bucks, and it fit pretty perfect.
Also, I decided to finally cut my dash for a modern head unit. With full autometer gauges, rear fuel tank, shaved stake pockets, modern seating, painless harness, billet everything etc, the original radio would look out of place (plus reching for the glove box is kind of a pain...)
Old 12-31-2006, 05:36 PM   #40
msgross
msgross's Avatar
That's why all modern radios comes with a remote control.. .I use mine in my car so I don't have to take my eyes off the road, sad to see a dash get cut but I like the gas tank filler. Think I should go that route vs. trying to cut my own? thanks...
msgross is offline   Reply With Quote
Old 01-07-2007, 02:32 PM   #41
muddpile
muddpile's Avatar
Remotes work fine until it comes time to change a CD. I figure I've cut the rest of the truck apart, whats a few more in the dash if it makes me happy right? As for the gas filler plate, I would NEVER attempt it when this product is available for 10 bucks. It fit excellent, was nice and thick and welded up great.
New update time as well! Both cab corners and both rockers are now in. I can actually look all over in my cab and not see daylight anymore! That may not sound like much, but it means the world to me,
Scary isn't it? That mangled, wrecked mess that I started with is now coming together, and rather quickly. I HIGHLY reccommend Goodmark/Tri-Plus panels if you are restoring one of these trucks. I'd never welded before I started this, and hardly worked on a vehicle, and look what I've done. Just imagine what an experienced person could do.
Here's my new favorite shot. I call this one "It's almost a truck again"
Old 01-07-2007, 07:29 PM   #42
FarmTruk
In Memoriam...
FarmTruk's Avatar
Muddpile, I just saw this post, and read it from start to finish. You're work looks great. Man, whew, that's a lot of work. This is inspiration for me too. I'm keeping my eye on this one for new updates. Keep up the good work.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-07-2007, 09:34 PM   #43
65-72 chevytoys
65-72 chevytoys's Avatar
Way to go. Keep going I am going to watch this one if you can weld that well the first time then I think I should give it a try.
65-72 chevytoys is offline   Reply With Quote
Old 01-07-2007, 11:24 PM   #44
harmsy
Looking good , mine is also orange and white , just complete.......
harmsy is offline   Reply With Quote
Old 01-07-2007, 11:43 PM   #45
turbochevy
nice work! I am looking forward to the end results. What are your plans for mounting the seats? I have the same seats, and I am holding on until I can come up with an answer on the installation of them. I plan on removing the in cab tank sooner or later too, do you think I can run the buckets with the tank for now?
1970 Chevy C 10 SWB
turbochevy is offline   Reply With Quote
Old 01-07-2007, 11:57 PM   #46
YRU351
YRU351's Avatar
Where are you going to put a new gas tank? I'm interested in doing this also/
Not Sponsored By Mommy And Daddy Kustoms
YRU351 is offline   Reply With Quote
Old 01-08-2007, 12:22 AM   #47
projectking
projectking's Avatar
wow great job on the truck, makes me want to stay up all night and work on mine!!!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 01-08-2007, 01:06 AM   #48
muddpile
muddpile's Avatar
Lots of comments and compliments, thanks guys. I never had any idea of how fast it can come together once everything lines up. Now, answers to some questions:
TurboChevy: The seat mounting was a pretty involved process, although it didn't have to be. I wanted the most leg and head room I could get, as I'm not that small of a guy (6'0, 230+). What I did was slid the sliders right to the back of the seat, like where they would be if you slid the seat all the way forward in the vehicle. I then set the seat sliders down behind that thick floor rail that the front of the stock bench mounts to and checked for fit. The seat backs just barely touched the back wall above the tank, and there was lots of head/leg room. I then marked where each mounting place was for both seats (8 total) and set the console in between to make sure it fit.
Once everything was marked out and to my liking, I measured to see how thick of bolts I could fit in the seat holes, then drilled a pilot hole and then the real hole (which was about 1/8" bigger than the bolt for easier threading). I then tipped the cab back to do the cab supports, and while under there, I welded washers with the biggest outside diameter I could find to the floor (making sure the nuts would still sit somewhat on the washer for structure). I then centered the nuts and welded them on as well. I welded them VERY well, so they would not come off, then covered my welding with seam sealer to keep rust and whatnot away. The setup seems very solid and I am confident it will hold up well.
The seats actually fit very well with the tank in the cab. Up until about a month ago I was going to keep the in cab tank, but decided to switch to an under-bed model to save some interior space.
YRU351: I plan on mounting a 72 Blazer tank under the bed where the spare tire would normally hang, and filling it through a marine style filler in the bed floor.
Old 01-08-2007, 01:39 AM   #49
groundhog
its looking good just hope you have the energy to keep going .im kinda doing the same thing to my 71 but with out the cab removal ill post pics soon...keep it up and it'll come around keep the pics coming...jc
groundhog is offline   Reply With Quote
Old 01-08-2007, 03:35 PM   #50
birdie
birdie's Avatar
That is great work you are doing, your truck is going to look fantastic when you are done.
1946 Chevy ton truck
1972 Chev C30
1975 Scottsdale C10
birdie is offline   Reply With Quote
