Old 05-21-2006, 11:52 AM   #26
ChevyDude
Re: Auto crossmember question...help.
Originally Posted by ABHaulR
i allways understood that the spline count on the 350 to the 700r4 where
diff
NOPE! If you do a search on google about the 700r4 and yokes...it won't be long until you will find the info the says TH350 and 700R4 have the same yoke. Now what I have under there is another question?? Good job for bringing it to my attention...gonna find out after I walk the two doggies!!!
ChevyDude is offline   Reply With Quote
Old 05-21-2006, 02:40 PM   #27
powell72
powell72's Avatar
syncronized rawhide chewing, what well trained dogs.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 05-21-2006, 03:26 PM   #28
ChevyDude
Yup sychronized pups!!! Anyway I am to the point of being pissed off. Unbolted everything and moved engine to the front tower holes and it seems my towers do not line up on the front holes??? I am going to see if I have old pics that show me where these towers were??? The crazy thing is Lemields engine was sitting on the front two holes..but his truck is a 70'.
Help...Mr wizard!!!! Trizzle trazzel trazzel trone, time for this one to go home!!!
Ok found old pics...I had it in the right spot to begin with, 1971 and 1970 towers must be different??? Ok back to square one. This is a classic case of three steps forward and 8 steps back!
Old 05-22-2006, 12:04 PM   #29
72MARIO
72MARIO's Avatar
Hey buddie you made your self alot of extra work there. Jeez...... You can use the stock V8 or V6 motor mounts with a V8.(Bye the way thoes are 6cyl mounts not that thats a problem) Your buddie has stock V8 mounts in his truck thats why it further ahead. It does not matter where you have the motor the tranny crossmember will not line up with the existing holes. I cant believe you pulled the motor oh well put it back in on the mounts where you had them.
Then make sure you roll the floor to fire wall pinch weld up so you have a little extra clearence fot the slightly taller 700R.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-22-2006, 12:13 PM   #30
ChevyDude
Good info Mario!!! That's why it didn't line up. I didn't actually pull the motor...just ubolted it all and hoited it and tried to bolt it in the front holes...Jeeeezzzzz...what a doooooomazzzzzzz! Ok great info though...6cylinder towers I have here ehhhh....those gotta go. Where can I get some
V8 towers because it sure would be nice if the engine sat 2" forward in the bay???
Alex
Old 05-22-2006, 01:45 PM   #31
Lemield
Lemield's Avatar
Alex
I didn't know those were 6 cyl towers either. dooooooomazzzz #2 here!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 05-22-2006, 02:17 PM   #32
TugOwar
Alex
I thought everyone wanted the engine to set BACK as far as possible? Leaves more room for electric fans, serp setups, etc.
TugOwar is offline   Reply With Quote
Old 05-22-2006, 02:37 PM   #33
ChevyDude
Good Point! Something to consider...and Then I would have to unbolt it all again!!!
Old 05-22-2006, 11:53 PM   #34
powell72
powell72's Avatar
I've got a set of V8 stands you can have if you want to run up to Windsor.
Chris
Old 05-23-2006, 04:09 AM   #35
ChevyDude
That would be awesome!!! Is this Sunday good for you, if I was to run up north and come get those?
Thanks,
Alex
