05-24-2006, 08:31 AM | #26 | |
Re: Would gears solve this
05-24-2006, 01:49 PM | #27 |
Next project: 1970 K10
I personally don't think you can come to any sort of conclusion until you hook up a working tach and see what is really going on at 45 mph, 55 mph, 65 mph, etc. Once you have solid engine speed numbers in hand, than it would be much easier to point at rear end gearing, tire size, clutch slippage, that sort of stuff.
Oh, and try this site. Plug some numbers in and see what you come up with: http://www.csgnetwork.com/multirpmcalc.html According to this calculator, with a 29" diameter tire, 3.73 gears, 1:1 final trans gear ratio, at 65 mph you should be turning around 2800 rpm's +/-. Even with a 4.56 gear, all other numbers the same, it shows 3434 rpm's. Of course these are just averages, but using the numbers from my 68, they are pretty dern close!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 05-24-2006 at 01:57 PM. |
05-24-2006, 02:46 PM | #28 | |
its all about the +6 inches
forget the 4.56 gears, he has a 1/2 ton.
a 3.73 gear (standard with the 3 speed) WILL slow down fairly quick when you lift... pretty much any gear in these trucks will, even the 3.07. Quote:
05-24-2006, 03:27 PM | #29 | |
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
05-24-2006, 03:28 PM | #30 |
put it on a hill, put it in neutral, see if it rolls, or push it on level ground, sounds like u got somthing hanging up, check the e-brake.
05-24-2006, 08:50 PM | #31 |
I was pondering this as I was screaming down the road in the truck today.. (I hit...4000 RPM... 4.10 gears, 37 inch tall tires, TH350, do the math ) and was thinking a few ppl have mentioned something binding...
However, if something was holding it back, say a hung up brake, the RPM's woulnd't be sky high as indicated. The only way the RPMs can be hich, is if there is slippage in the tranny/clutch, or tire smoke... that's it. |
05-25-2006, 12:07 AM | #32 |
andy you got 37" tires on the longhorn?
common sense isn't so common anymore |
05-25-2006, 05:23 AM | #33 |
Oops, that was supposed to say 31 inch. LT235/85 16
05-25-2006, 09:27 AM | #34 |
well going off Longhorn's theory of loud exhaust. I have 3.73 and dual exhaust. I previously took out the carpet and what not, and I thought my truck was going to BLOW UP going down the interstate. I put some sound deadner in the cab. Now it sounds normal inside cab. Just a thought.
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
05-25-2006, 11:04 AM | #35 |
Insert Title Here
ok, well after reading everyones posts, I think its a mix of both........ for one yes it rolls in neutral, and it shifts into all 3 gears just fine..
so I'm going to assume its a little of both, that it has to much of a gear in the rear (for towing), and that Its also my first vehicle without overdrive, so some of it might be normal but just not use to... either way, im not satisfied with the 3 speed so ill be looking for a tranny first, then see about gears... Thanks for all the replys
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 05-25-2006 at 11:05 AM. |
05-25-2006, 11:41 AM | #36 |
That explains a bit....without OD you'll n o doubt think it's winding hgiher than it is. I would not go to an OD tranny unless you get a 4L80E or something newer. Best idea [albeit expensive] is a TH-350 with a Gear Vendor OD unit behind it.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
05-25-2006, 12:43 PM | #37 | |
