Post Whore
![]() Join Date: Feb 2000
Re: Autometer gauge cluster- Gringoloco style*
That looks great! That will compliment your truck very well!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
![]() Join Date: Jul 2006
I like those a lot. Nice choice. I already blew my waud on my gauge cluster. If I do it again I'm going that route.
looks great
Still drivin' a Rat Rod
Gives it a nice clean look,and still all the gauges in a small package.I like it.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
those do look great. almost makes me wanna switch to a 3-hole cluster. on the other hand, i bet one could find a few other gauges to fit in the lower 4 holes...(boost pressure, air bag pressure, etc.)
i was actually contemplating the same type of set-up, except using a 5" tach and 3-3/8" quad. after finishing your set-up, do you think a 3-3/8" quad would be too small to read?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ Last edited by cstanley; 06-06-2006 at 08:26 AM. |
#6 | |
A guy with a truck
Looking at the quad, the needles are already pretty small. It would be easy enough, though, to know if something is going wrong. I figure, if one of the needles in the quad falls below the halfway point- you got problems- or are running out of gas... The quad in the middle would give a nice symmetrical look to the cluster too. ![]() Here's a crummy MSPaint hack of your idea; I think it looks pretty good. Also , on the 5" tach, you lose the zeros.(1,2,3... instead of 10,20,30...) Much better looking in my opinion. -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
TTT.... Dusting this one off. Why is it they can't make the full spectrum on all their gauge lines?!
I was thinking along these lines & filling the lower holes w/air gauges. Guess what? Autometer only makes the air gauges in certain lines..... and those lines don't offer the quad gauge. Check other manufacturers & it's the same problem. They either offer quad gauges but no air-psi or air-psi & no quad gauges ![]()
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-12-2006 at 01:51 AM. |
#8 | |
A guy with a truck
Where does one get a 3 hole bezel like that? Did you have to make it yourself?
Thanks, Chad |
Yep.... But, if it doesn't match, it's not worth spending the $$ to switch.
![]() ![]() Join Date: Jul 2002
The cluster looks very nice!
you could always just get classic instruments to custom make you a set - a sort of package, if you will. i called them once about custom gauges, and iirc, they weren't much more than the standard sets. 'course the standard ones are spendy anyway...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
#13 |
Insert Title Here
When I had my old s10 I had all the silver faced Auto Meters.. Pro Comps I think, and also had two matching PSI gauges for the airride.. they were nice gauges
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 12-12-2006 at 11:41 AM. |
#14 | |
I really like the Classic Instruments 'G/Stock' Classic Series. They have a sporty 60's/70's muscle car/factory look to them (they're a retro looking green/silver silk-screen print). They offer a quad gauge, speedo, & tach.... in a 3 3/8" or 5" diameter; but no smaller air psi gauges. That was my direction. Those gauges in the factory top 3-holes (5" speedo, 3 3/8" tach, 5" quad) & then matching single air gauges in the lower 4 holes. Perhaps I can have the smaller ones made?????? I'll make a phone call.....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-12-2006 at 05:18 PM. |
#15 | |
Ouch.
#16 |
that looks awesome! props on being different! shows you theres more to life than 'gauge style' bezels!!
-1947 3100 -1968 C10 -1970 K20 |
#17 |
That's hot!
#18 |
Insert Title Here
triple ouch
I think when I do my air ride im just going to do dakota digital in a center council or something. so I dont have to worry about it mismatching the dash gauges
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 12-12-2006 at 06:00 PM. |
#19 |
I can't believe I missed this thread earlier! I was totally going to do this until I got a deal on my six piece set from a friend who sold the car they were going in.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
#20 |
All of the setups look great, I'm in the process of doing a 7 gauge dash in my 72 all in Autometer Phantom gauges.
1972 Chevy K20 15" & 44's 1986 Chevy K30 Crew Cab Longbed 6" & 35's Last edited by Big Ol'Chevy; 01-27-2007 at 01:23 AM. |
#21 |
Wrenchin & Sandin!!!
Hey Gringoloco....Any pics of the cluster installed in your truck?
Randy ![]() Shorewood, IL. My Favorite eBay Searches My Driver Restore Thread 1971 C10 Longbed 2005 Silverado Shortbed 2005 FXDWG |
#22 |
A guy with a truck
Not quite there yet...
#24 |
Hey gringoloco did you get the gauges at Summitt. any pictures installed.
R.I.P. Killer 71 10/26/07 |
#25 |
A guy with a truck
Yes Summit. No, not installed yet.
