Old 06-07-2006, 08:39 AM   #26
Huck
Huck's Avatar
Re: grrr, valve cover leaking oil
Leaky valve covers have been a small black issue since 55' but no amount of gaskets or sealer on the gaskets will help if the intake bolts have no sealer on them. You could get both oil and antifreeze coming up them holes which will drive you nuts. SEAL-em first then see what you have.
My experience has been best with cork valve cover gaskets but the install is more critical then the material. The 88-98 350's with injection are also notorious for intake gasket leaks which are a bugger to replace so just be aware~~~.
Huck is offline   Reply With Quote
Old 06-19-2006, 09:31 PM   #27
Daubs
Daubs's Avatar
When I installed alum intake I put RTV sealant around the ALL the bolt holes (both sides of gasket) but did NOT put thread sealer on the bolts themselves. Could that be case of my oil leaks?
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 06-19-2006, 09:34 PM   #28
MisterMan
MisterMan's Avatar
Originally Posted by 67Fleet
I just replaced the gasket on my driver side valve cover because it had been spitting oil onto my intake manifold. It's still doing it!!! I spent about an hour cleaning the bottom of the valve cover yesterday of the goop and then went to get some nice Felpro valve-cover gaskets (the rubber ones). I installed and put the valve-cover back on. It was a total PITA because they make the gaskets slightly smaller than the cover so I had to use a little gasket spray adhesive to get it to stay long enough to flip it over and stick on the head. Took it out and drove it up to my buddy's shop to help one of my club members bag his S-10. As I was driving home, I got on it a little and then smelled some burning oil. WTF??? Got home and its still spitting on the intake and also looks like down the backside of the motor. The cover doesn't look warped, and I can't see any of the gasket sticking out anywhere. What should I do? Could it be a leak from somewhere else?
it smacking ur intake manifold and causing a gap???
MisterMan is offline   Reply With Quote
Old 06-19-2006, 09:37 PM   #29
Gray Ghost
Gray Ghost's Avatar
Yes...on the middle two bolts on each side around the carb, you need a lot of thread sealer on each bolt. I forgot this last time and have a couple of leaks.
You CAN seal chrome valve covers, ya just haveta use studs and RTV and re-tighten after the motor warms up a couple of times.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
