07-30-2006, 04:00 PM | #26 |
Active Member
Re: New shoes on the Blaze! Finally!
Thanks ya the front is giving me headaches with the new tires. I need to go higher to quit rubbing on everything and most likely need to do a cross over setup because the current tie-rod setup tore the wheel weights off the rim the first time i moved it...
1969 C10 SWB /350 vortech/th400 1968 SWB build (in progress) 1969 SWB build (my son's future project) 1968 camaro yellow/white stripes (wife's car) 2011 GMC reg cab short bed 2wd daily driver 5/7 drop on 22's 1972 K5 Blazer 13"/11"lift,38"M/T MTZ's, 3" cust exst. 350/350 (sold it ) |
07-31-2006, 09:52 AM | #27 |
I was kinda wondering how 7" lift was gonna work with 38's. I have 11" and was thinking i couldn't go much more than 38's
If it aint broke..............fix it till it is. www.fast77.com 1972 - 330 hp crate, 11" lift with 39x18 mickeys. 3/4 ton, cross steer, 4 wheel disc brakes 1996 Z71 w/ 35's |
07-31-2006, 09:55 AM | #28 |
Post Whore
That is a great looking K5! Lots of nice touches.
Contact www.offroaddesign.com they should be able to get you just front springs.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
07-31-2006, 12:27 PM | #29 |
Looks great! Might need to notch those rear wheel wells a little though.
And now you need a step to reach the step. lol...
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
07-31-2006, 02:42 PM | #30 |
The LuvShack Garage
Nice set of shoes
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
07-31-2006, 04:25 PM | #31 |
Active Member
haha ya the step is going to be worthless after the lift but o well.... Thanks for the ideas on springs, I managed to figure out my game plan.
Rear will be 8" springs with flip for a total of 12" Front i have to buy 8" springs still with 1" zero rate and extended shakle to reach 10" The cross over steering i have most of, i just need to send out my knuckle to be machined. any suggestions on the drag link? I have the 2wd box, pitman and steering arms
07-31-2006, 06:24 PM | #32 |
Junior Member
Nice looking ride. How much clearance do you have at the front when the wheels are turned with the current lift?
07-31-2006, 08:08 PM | #33 |
Active Member
Baketown- Before when i had the 35's there was no probloms ever. with the new treads cranked one way the tire is only about 1 inch away from tearing my front fenders off.... cranked all the way to the passenger side my pitman arm hits the tire at almost full crank.
07-31-2006, 08:58 PM | #34 |
The Blazer King
Watch out for potholes. One big bump until the bigger lift and you are in trouble.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
07-31-2006, 10:41 PM | #35 | |
Gettinlow & Goinfast
i love the white!!! kick ass blazer man
Protouring Texas built rides- 78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390 71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html 70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo- 85' C20 crew, 5.3/6L90/S475 turbo- 68' C10 5.3/4L60/Level 2 coil overs Facebook- Protouringtexasdotcom Instagram- @Protouringtexas |
08-03-2006, 06:50 PM | #36 |
That is a sweet cage!!!! Where did you get it done? I have to see if my buddy can fab one up like that.
Rod
1987 GMC Suburban 1/2 ton 4x4 (Beater) 1998 GMC Suburban 2500 4x4 1972 Olds 442 Convertible 2006 GMC 2500 Duramax Crew Cab (Sold) 1972 Blazer 4x4 (Sold) |
08-03-2006, 11:31 PM | #37 |
Active Member
Hey thanks, ya i get alot of attention with my cage... expecially now that it is silver (it was black before and blended in).
It was fab'd in eugene at my buddies-dads-friends house. The top still fits on it perfect too.
08-10-2006, 10:12 PM | #38 |
PROJECT 7DEUCE
Sweet looking blazer I have the claws on my yota and had em on my blazer for a while and they did not seem to last long????
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-19-2011, 10:17 AM | #39 |
i hate to resurrect an old forum, but ......
how much lift was there in these photos (it looks lower then your 11/13") how are the 1/2 ton axles holding up to the 38s? what gears were you running? |
05-19-2011, 11:03 AM | #40 | |
Active Member
05-19-2011, 07:59 PM | #41 |
go cyclones
nice truck. How did your rims fit? Did you have to put any spacers in? Did you have any interference with the brakes?
05-19-2011, 08:37 PM | #42 |
Bad ass truck
