Old 09-05-2006, 06:24 PM   #26
cstanley
cstanley's Avatar
Re: 1/2 ton to 1 ton brake upgrade
Originally Posted by aboyer View Post
To stop her, I have to push the brake pedal down is far as it goes. When I get to the end, it finally stops. It is not a strong stop, just a very weak stop.
Do you think I need to adjust the brake rod on it? Do you suggest a certain length?
Adam
i assume you got the 3/4t MC to go with the 3/4t booster? the different MCs have different length pistons...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 09-05-2006, 06:33 PM   #27
aboyer
Adam B
Yes, I purchased a complete new unit, with New MC and new booster. I also bought the longer brackets as the new booster has a longer shaft than the orginal booster.
Do you think this is where I need to make the adjustment?
i don't want to change something like brake rod length and screw it up more than I have started. If I need to change it, how much do I change? Any suggestions?
Adam
aboyer is offline   Reply With Quote
Old 09-05-2006, 08:37 PM   #28
timcos
Chief Honcho In Charge
timcos's Avatar
I am noob. Why upgrade? It does not actually change the brake set up does it?
I guess the real question is why. If there is a goof reason I am going to do it to..looks like something I can handle.
Cheers,
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 09-06-2006, 01:26 AM   #29
nate68
you should probably try to adjust it, it can make a big difference
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-06-2006, 11:48 AM   #30
70rs/ss
70rs/ss's Avatar
I reused the rod from my 1/2ton booster. I bought the 3/4 ton set up (came as one unit) unbolted the MC to bleed it, bolted it back up and used the brackets that came with the booster. You guys are overthinking this and mixing parts, just stick with the new parts and your existing hardware. My brakes stop excellent, this upgrade is usually done on 4X4's not 2wd (I've never had an issue with a 2wd not braking good) The reason for the upgrade on the 4X4's is because back in the day they put single diaphrams in the booster for 1/2 tons, and double diaphrams in the 3/4 tons. The dual diaphram set up takes way less pressure on the pedle to achieve great braking (cures that rock hard pedal as well).
70rs/ss is offline   Reply With Quote
Old 10-30-2006, 08:01 AM   #31
Southedisto
River life......
Southedisto's Avatar
So I can use my stock 1/2t bracket and rod (PB setup) with a 3/4t booster and MC?
Southedisto is offline   Reply With Quote
