#26 |
Re: Best MPG for a 2wd 67-72
I get around 12-14 with mix. Straight hwy, I am around 15-16. I am carryin g a 500lb custom canopy/camper. Stock 350 motor, except the carb (Edlebrock 600cfm), and new 3" single exhaust. I know, at the time I could afford dual exhaust, and I was tired of the exhaust coming into my cab whenever I had the windows down. 3.73 gear, th350. I believe I might get better if I didn't have the camper on it. Well see in the future.
#27 |
God Bless Mr. T
1965 GMC 2wd longbox stepside
283 2 barrel, granny gear 4 speed (SM420 I think) 3.07's, points Pulling a 4x8 trailer with a yard tractor all day, around 14 mpg. My trick was to shift at the lowest rpm's I could and do ABSOLUTELY NO jackrabbit starts or powershifts.
Like a midget at a urinal...sometimes you must stay on your toes. |
#28 |
I thought my wife's truck was kind of a hog, looks like we're doing pretty good! 1968 swb .040 over 350 with speed pro hypereutectic flat tops. Comp Extreme Energy 268h cam. Worked over 1406 (305 H.O.) heads for a 9.8:1 comp. ratio. Edelbrock Performer RPM intake, Holley 600cfm va. sec. 4 bbl. Stock HEI dist. Hedman long tube headers to 3" pipe breathing through Full Bore mufflers. TH350 trans with B&M 2200 stall, 3:73 rear gear and 295/50-15 tires. Getting about 14 mpg average mixed driving. Got 8mpg two weeks ago pulling a 2500# trailer with 4200#s of scrap iron over about 50 miles!!
#29 |
Out of the carpool lane.
After finally getting all the bugs worked out of my drivetrain for the most part, using the 250/T-5 combo I'm getting about 17mpg @ 65mph. My engine has about 140,000 miles on it and I think it might be .30 over, but can't remember. These L6's aren't known for their high compression and I suspect with a good solid rebuild and 9.5:1 comp ratio, I could get kick @$$ mileage from this. Most likely in the spring I'll experiment with a Q-Jet and try to get better mileage since they have smaller primaries.
Since I know I'm getting 17 @ 65mph, I should be getting higher mpg's at 55mph. That's on a tired, old engine! My eventual goal is 21-22 mph highway! I used a GPS since my speedo is just slightly off. I notice that when it says 75- I'm actually doing 70. 55 is about 54, etc. That's why I don't really trust many of the numbers thrown around this board regarding mileage- even what people tell me in person until I can really question how they came to their conclusion. Here's my combo: Rebuilt 250 w/possible .30 over pistons, stock cam as far as I know, 500 cfm 1403 w/stock jetting and rods, HEI which probably needs a rebuild, Clifford intake and shorty headers, dual exhaust with H pipe, Camaro T-5, 3.73's in the rear, tonneau cover on bed, 275x15x10" tires in back 245x15x8" tires up front. If I were to put thinner tires on it that would help mileage due to less rolling resistance.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 10-22-2007 at 11:16 PM. |
#30 |
At over $5.00 a gal I don't sweat it. I know you want facts and figures but I'm still going to drive my trucks and car's and I'm not selling anything so I figure why depress myself. I just enjoy that moment that I'm cruz'n.
esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 10-25-2007 at 01:15 AM. |
#31 |
Senior Moment
![]() Join Date: Mar 2002
Big Block, Lots of fun - Gas mileage? Who Cares
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#32 |
18.5 mpg, TPI 350, adjustable fuel pressure regulator (which I could turn down for a little bump in mileage), K&N cold air setup, 700R4, 3.73 gears, 275/50/17 tires, headers, 2.5" exhaust.
Oh, I run 92 octane too. |
#33 |
[QUOTE=Brad;2414923]
I used a GPS since my speedo is just slightly off. I notice that when it says 75- I'm actually doing 70. 55 is about 54, etc. That's why I don't really trust many of the numbers thrown around this board regarding mileage- even what people tell me in person until I can really question how they came to their conclusion. I know what you mean , I question myself as to how accurate is my gauge ? how accurate is my speedo ? I suppose it wont matter if everything is consistant you could still check for improvements or loss . Another thing I wonder (maybe I think too much) is "click off" from station to station , is it the same ? Bottom line is I want to drive my old beater truck (and I will ), but having decent MPG would sure help back to the question , 9-11 MPG soon to improve with any luck !
"I feel the need for speed!"... as soon as I am done with my nap. |
#34 |
I have a radical idea!
'69 C/10 SWB
Engine: Rebuilt 350 (.030 over so its really a 355) with flat top pistons and 882 heads making the CR 9 : 1, stock CS-274 cam, Q-jet on stock non EGR manifold, HEI, clutch fan, ram horn manifolds 2 1/4" dual exhaust. Trans and Rearend: TH350, slight towing style shift kit, stock converter, 3.08's Tires: P235/70/15's on 8" steel 6 lug rallys I get 13-15 in town, 16-17 highway. I do mainly mixed driving and I usually get about 15 consistantly. I am going to be adding TPI and 275/60/15 tires in the near future, and I'll come back and post results of the new combo.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 10-25-2007 at 05:13 PM. |
#35 |
Love that '69
1969 C/10 LWB
Engine: SBC 283, stock internals, Q-jet on stock cast-iron 4BBL manifold, HEI, dynomax full-length headers into 2 1/4" dual exhaust with magnaflow mufflers Trans and Rearend: TH350, stock converter, 4.56's Tires: P235/75/R15's I normally get about 12-14 MPG combined. Gas Mileage.......LMAO!!!! Thats one thing I don't really care about with my truck. Its a cruiser, not a daily driver. I have my 2001 Cavalier Z24 with a 4 banger for gas mileage and daily driving.
I AM CANADIAN & PROUD OF IT!!! ![]() 1969 Chevy C10, SBC V8, TH-350 Transmission, Metallic Blue, B&M Megashifter, GT Grant Steering Wheel, 2.25" True Dual Magnaflow Exhaust System w/ SS Magnaflow Embossed Tips, 700W Rockford Fosgate Stereo System, Lowered 1" Front & Stock Rear, 4.56 Rear with Positraction, 15" Chrome Rims w/ Chevy Center Caps & Michelin Tires, 4.5" K&N Air Filter, Edelbrock 'Elite' Engine Accessories, Chrome Powdercoated Engine Parts 2001 Cavalier Z24, 2.4L DOHC, Silver, Spoiler, AEM Intake, 2.25" Magnaflow Exhaust System, Clear Euro Tails, Tinted Windows, 400W Clarion Stereo System Last edited by gkolmatycki; 10-25-2007 at 05:49 PM. |
#36 |
i get about 15 mixed driving in my 69 lwb c10 with a junkyard 350 from a 80 chev pu sm 465 with 3.73 gears. i have 31" tires. it's timed by ear till just shy of pre-detination needs an air filter and i never looked at a plug. i'm very easy on the throtle, never opening the secondarys, building speed before hills and backing off as vacume decreases.i travel at 65-70 mph alot so a set of 3.07s are in the plans. it needs valve guide seals so i'm gonna mill the heads to up the compression, do a good 3 angle valve job and set up a new hei. with that and a good carb tuning i'm thinking 18 - 20 plus is not out of reach with a light right foot
common sense isn't so common anymore |
#37 | |
Wow! Are you serious? 30+ non-highway MPG in a C-10 by swapping to a Cummins Diesel? Tell me more...........
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
#38 |
about 13 mpg on the highway @ 65, when im trying to save fuel..
suckin gas.. and haulin ass! ![]()
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. Last edited by 69halfton; 10-25-2007 at 07:52 PM. |
#39 |
Right on!!!!! It's worth the price for the rush. edll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) |
#40 |
![]() Join Date: Nov 2006
17.5 to 18.2 if i drive it right. 383 w 400 rods, towing cam, dart II BIG VALVE HEADS, 10-1 compression srp pistond, q-jet on iron maniflod, roller rockers, hei dist. th350 w/3.08 gears. i couldnt believe it. i triple checked it on my 250 mile trip to woodbridges picnic this summer. my 250 I 6 with 3 on tree and 3.73,s only gets 13-14 empty running 60 mph. 11-12 loaded
bob
I BELIEVE IN JOHN 3:16 |
#41 |
anybody running a 327? I bought a 71 with a 327 with a 350 tranny and wondering what i would get mpg. it has 3.08 gears. and how much would a 700R4 improve the gas mileage?
#42 |
Mine improved it about 5-7mpg. I purchased a lock-up style 700R4.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
#43 |
I did have a 327 TH350 with 3.08 gears. It had a Comp 268H cam and edelbrock carb on it. It would get ~12 mpg.
