12-19-2006, 02:00 AM | #26 |
Re: Air compressor vers compressed air tank
12-19-2006, 12:47 PM | #27 |
Helium is no faster than Nitrogen, Ambient Air, or Compressed Farts.
Again, the molecule size of the gas has nothing to do with the "speed" of an air suspension system. The "speed" you refer to may have something to do with the fact that you are pushing a gas at 350 psi thru your system. I don't think a 12 volt or a belt driven compressor based system can't obtain these pressures, at least not economically. Any gas "pushed" at 350 psi is gonna be "faster" than a gas "pushed" at lesser pressures. To give the credit to Helium for it being faster is hilarious to me. Last edited by Shane; 12-19-2006 at 05:32 PM. |
12-19-2006, 01:40 PM | #28 |
Seņor Member
"Thickness" isn't the issue. I can get Jell-o to move faster through lines than Helium with enough pressure. Hmmm... a Jell-o cannon.
Ideal gas law (a bit of a combo of Charles' Law and Boyle's Law... it has no implications toward density, only pressure, volume, and temperature).
12-19-2006, 01:43 PM | #29 |
Seņor Member
No, medical grade N2O would be hilarious. He only changes the pitch of your voice.
12-19-2006, 03:00 PM | #30 |
i have a eng driven compressor that i can fill my tanks to 175 compressed air and also run a nitrogen system that i can set at 175 so same psi same size lines same valves and weight of vehicle and the nitogen is faster and when ran with a helium cylender at same psi it moves even faster than with the nitrogen
so i think there is something to the speed that the smaller molocule gas moveing faster
http://www.cardomain.com/ride/2461088 |
12-19-2006, 05:30 PM | #31 |
Basic Physics states otherwise, but who am I to argue.
To expand on XXL's post, here is a little insight on Molecular Composition & Kinetic Energy. |
12-19-2006, 06:58 PM | #32 |
Seņor Member
To expand on Shane's post... you're incorrect.
12-19-2006, 11:48 PM | #33 |
I am? Ah $hit, and I thought I had this one going in my direction.
12-19-2006, 11:57 PM | #34 | |
12-20-2006, 02:13 AM | #35 | |
Seņor Member
12-20-2006, 01:25 PM | #36 |
yea i dont really care about the physics behind it all i know is when its hooked up to Helium it looks faster sounds louder and hops higher
the only problem is it cost more $$$ so its vary rare when it gets used in my truck i am not a scientes only a metal fabracator its all about the fun and the sweet looking trucks
12-24-2006, 01:53 PM | #37 |
Maybe its the same thing as that 20HP gain by adding a resistor to the mix of your temp sensor on the intake? It feels like 20 HP, but really isn't anything... all a mind game because of the myths of a few passed around the net.
12-24-2006, 02:26 PM | #38 | |
Seņor Member
12-24-2006, 05:08 PM | #39 |
I would love to have an additional 20 hp, but my temp sensor isn't on the intake.
12-27-2006, 07:17 PM | #41 |
Junior Member
You guys are too much man...... all of these years of plowing around the internet, I dont think I remember seeing that web site before.
12-27-2006, 07:52 PM | #42 |
Seņor Member
Around 2003, I made it to one edge of the Intarnetwebs. I am now headed back the other direction in search of the other edge.
12-27-2006, 11:58 PM | #43 | |
XXL - Looks like you didn't hit the porn side yet, I was in the same situation as you a few years back and after I passed everything I'd already seen, I found porn.... and now I don't think I'll ever make it to the other side. |
12-28-2006, 01:17 PM | #44 |
Seņor Member
Oh I think I've got that covered pretty well... :happy:
12-28-2006, 03:17 PM | #45 |
Junior Member
Slammed has gone to the dark side.....
12-28-2006, 06:16 PM | #46 |
i have to look up xxl's other posts to see if he can beat this one
12-29-2006, 04:45 AM | #47 |
I did?? I mean, yea, I did! (psst: Whats the dark side?)
