Old 09-19-2006, 05:04 PM   #26
Gimix
Gimix's Avatar
Re: photo story of custom gas filler.....
Well I was just wondering but I know I've seen cars do it as well.The last one I seen was in Texas and a guy just bought a new Ferrari Enzo and he went to fill it up and BOOM!and he wasn't smokeing.
Originally Posted by John Fabris View Post
Gimix, Unless you are rubbing all over your cloth interior while you are filling up, you won't have a problem with static electricity.
Even then, touching the truck or the pump itself with your hand to release the charge before removing the nozzle will take care of that.....
And for those that worry about the spark created when you turn your lights on or when you apply the brakes, my set up is a sealed system and even if I were to have sloppy wireing or loose fitting lightbulbs, it would not be an issue...
Gimix is offline   Reply With Quote
Old 09-19-2006, 05:33 PM   #27
67ChevyRedneck
67ChevyRedneck's Avatar
Can you prove this? Sounds like an urban legend.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-19-2006, 05:40 PM   #28
Yukon Jack
Post Whore
Yukon Jack's Avatar
That is a great modification. I need to get a one way check valve for my tank on my flatbed. Have to look into something like you bought.
Do you have a pic of the check valve?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-19-2006, 10:43 PM   #29
project1971
project1971's Avatar
That is clean! excellent job!
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 09-20-2006, 10:58 AM   #30
John Fabris
TOTY 2006
John Fabris's Avatar
Hey Yukon Jack,
These are them... They are about 3/4 - 1 inch long, and you can see the nipple where the hose is, that is the part you put into the tank, and if you look closely you can see the opening all around the bottom of cap, that is where the outside air get sucked in....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 09-20-2006, 11:22 AM   #31
layedoutnoma
layedoutnoma's Avatar
a quick google search and nothing came up.. sorry but its prolly not true...
Meticulous Fabrications
Milford Michigan
layedoutnoma is offline   Reply With Quote
Old 09-20-2006, 12:23 PM   #32
John Fabris
TOTY 2006
That one could be real or not, but with any car or truck, if a person has a static charge built up on them (as the case with most women as they are the ones that get back into the car while they are filling up), there is a risk of creating a spark with the nozzle as they remove it from the car.
It has happened and there are videos of this, but it is rare. If you touch the pump or car with your hand before removing the nozzle, you remove the risk....
John Fabris
67 C10 SWB
Old 09-20-2006, 12:24 PM   #33
layedoutnoma
yea it def has and can happen.. but i haven't heard the enzo story..
Milford Michigan
Old 09-20-2006, 12:58 PM   #34
salazar44
65 - Chevy C10
salazar44's Avatar
That looks sweet. I want to do the same for my 65. My tank is still in the cab. Do you think it could be done just to replace the ugly look of the stock filler?
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 09-20-2006, 01:46 PM   #35
Zumo
Hot Rods For Life
Zumo's Avatar
You fantastic bastard! That's awesome.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 09-20-2006, 03:57 PM   #36
John Fabris
TOTY 2006
Zumo, Thanks!!!
Salazar, if you are talking about this for cab, it should work, I would actually weld a thicker piece of metal to close up the cab hole, then weld a filler like this onto that piece. Other then that, cut and remove the filler tube inside the tank, and get the rubber gas filler hose and clamp to the tank and your new filler.
John Fabris
67 C10 SWB
Old 09-20-2006, 06:02 PM   #37
salazar44
65 - Chevy C10
salazar44's Avatar
Zumo, Thanks!!!
Damn John... Thats sweet. If only I had a welder! or at least knew how to weld! LOL I think I will just solder it on... J/K
I think I found similar "Deck Gas Fills" at www.overtons.com ( a boat parts shop ) and on ebay of course.
VIC
Old 09-21-2006, 09:58 AM   #38
Hook'em
Hook'em's Avatar
That is by far the best looking filler set-up I have seen.
Hook'em
Hook'em is offline   Reply With Quote
Old 09-21-2006, 11:44 AM   #39
shifty
Questionable
shifty's Avatar
A++ writeup! Thanks for the vent info, would have never thought about using one of those guys.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-23-2006, 11:27 PM   #40
zenish
is that watertight?is the tank going to fill with water when it rains?
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 09-24-2006, 12:38 AM   #41
LowRodder
LowRodder's Avatar
I got a pop up filler similar to the one you installed, and I was planning to use the same pocket that you did. But... my body man told me that he would have to cut out some brackets inside the pocket too run the pipe, and this would weaken the bedside. have you had any problems?
LowRodder is offline   Reply With Quote
Old 09-24-2006, 01:22 AM   #42
John Fabris
TOTY 2006
Huh
zenish, Fill up with water?? With a gas filler made for a boat
What it is that you think this will fill with water when it rain? Can you explain?
LowRodder, I used a 1-1/2inch gas filler hose for inside the pocket, and I did not use any brackets to secure it. With it being clamped at both ends, it does not move...
John Fabris
67 C10 SWB
Old 09-24-2006, 01:42 AM   #43
Josh
He's got mean nasty FANGS!
Josh's Avatar
Excll;ent mod, copied to FAQ
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 09-24-2006, 10:04 AM   #44
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
John, I think LowRodder is talking about a bracket inside the stake pocket hole, about 8"-12" down from the top. I have been trying to figure out how to get that out with twisting up the pocket. Did you drill out the spot welds?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-24-2006, 11:28 AM   #45
John Fabris
TOTY 2006
I forgot about that part, yes, there is the piece of metal that is the stop or
the bottom for the stake pocket. When I opened up the hole at the top of the pocket, then I used a chisel and hammer to knock out this stop. It is held on by spot welds, and you make get lucky and have it pop right off if the spot welds are not that deep (as in the case with mine).
NOTE added this to my steps above!!
Thanks for the clarification glock!!
John Fabris
67 C10 SWB
Old 09-29-2006, 06:23 PM   #46
Gimix
Gimix's Avatar
I seen it on the news when i was in texas,it wasnt told to me.I seen the video my self.A quick google search might not be the best way to some up if somthing is true or false.
Old 09-29-2006, 08:14 PM   #47
glock35ipsc
I found this story...Washington, not Texas....
http://www.cbsnews.com/stories/2005/...in706202.shtml
Bob
Old 10-03-2006, 02:47 PM   #48
HuggerCST
HuggerCST's Avatar
Great job, John! Any trouble filling the tank? Can you tell me how big around your cap is? (OD) I'm considering doing something similar to this.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 10-03-2006, 02:53 PM   #49
67ChevyRedneck
Wow, that's amazing, but there was no mention of how the fire started?
Jesse James
Project "On a Dime"
Old 10-03-2006, 03:46 PM   #50
John Fabris
TOTY 2006
HuggerCST, no problems filling with the nozzle opened all the way. (where as some of my buddies trucks with rear gas tanks, they have to slow fill to avoid the spill over.)
With my setup, I use a rubber pad over the filler hole on the bed (about a 3"by4") so that I scratch up the paint with the gas nozzle. Other then that, and the end of the fill, I do sometimes get gas vapor/spray around the filler, so I then clean with a rag, but it is never enough that gas is running down the bed....
I think the OD of just the cap is 1-1/2"
67chevyredneck, I am willing to bet that it was static electricity....
John Fabris
67 C10 SWB
