Old 09-20-2006, 08:52 PM   #26
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Would a tow bar be safe?
Originally Posted by 84 400 View Post
Well if it is neutral then it would not be in the lock position.
Couple things on that... most of us have the 67 - 72 trucks... esp since this is that segment of the board... and our columns don't lock.
Plus, onless you have a stick, you need to remove the drive shaft anyways.
I got my first one at wall mart for 100 bucks, but most wallmarts stopped selling them (check the RV section)
You can look in your yellow pages for trailer repair/sales/supplies store. Not semi trailers, but the ones ppl haul cars or lawn mowers on. You can look up RV dealers, or just go online and get one. E-bay has them, overstocked.com used to have them all the time, reese .com has them..
I would not recomend tellin U-haul you are using there junk to tow a bug... first, i wouldn't recomend renting there junk at all.
Old 09-21-2006, 01:44 AM   #27
jimfulco
Make sure everything's tight before you leave, then stop after 100 yards or so & retighten. Check it again after a mile or so, then again after a few more miles. Stuff jiggles loose.
jimfulco is offline   Reply With Quote
Old 09-21-2006, 02:22 AM   #28
69face
69face's Avatar
safe enough i towed my little brothers truck 80 miles at 55mph.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 09-21-2006, 12:18 PM   #29
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I think I got mine at Wally world too Andy, and it was like $50. Towed the Blazer from Puyallup to Bremerton behind the Suburban. About 60 miles all told. No problems. I tied up the steering wheel though, should have went with it loose. Made those tires drag that way. No worries, just do it! And be careful....
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 09-21-2006, 04:54 PM   #30
Longhorn Man
man, on passenger vehicles on public roads (excluding millitary stuff) I have tow bar'd;
one stripped truck, only bed and rolling frame with no steering gear box and the wheels bolted in the straight forward position, pulled with a SWB 69 GMC,to the junk yard, 10 miles
Pulled the 69 SWB GMC with a 25 foot moving van 1200 miles from tx to oh.
Pulled a ranger 3 times locally, ending up at the junk yard... 20 miles or so total, pulled with the 69
pulled the 70 one ton longhorn from PA.. 50 miles west of Philly to here... 650 or so miles, towed with an 87 k/5.
Parts truck (again, rolling frame and bed, and also with no steering gear box and the wheels bolted in the forward position) 10 miles to the shop to cut it up.
Dragged an S-10 from fort Wayne to Here with the 69, can't even remember the miles on that one.
All this with only that one incident I mentioned earlier, and it was easy to steer and throttle out of trouble.
Old 09-22-2006, 11:51 AM   #31
72swbcamo
Active Member
For ChevyBill, and LomghornMan, or anyone else who might be interested:
The reason the towed vehicle does not have to have the steering wheel tied or locked is that the front suspension on cars and trucks has geometry build into it what will make the tires try to stay straight or track during turning. When you have your front end aligned the technician checks and/or adjusts as necessary the caster, camber, and toe-in of the front end. The caster of the front end is the degree that the front wheels are tilted off the vertical. This angle causes the front tires to want to stay straight. The principle is similar to the front wheels on a shopping cart, (caster wheels), they will track straight going straight or track the towing vehicle in a turn. Hope this explanation help.
72swbcamo is offline   Reply With Quote
Old 09-22-2006, 09:45 PM   #32
Blue85
Oilfield Trash
Blue85's Avatar
Originally Posted by sneakysnake View Post
Nothing like a chain and piece of pipe for brakes and a pair of "vise grips"for a steering wheel.LoL
More details on this please, could be a good idea for yanked vehicles around the farm, pretty sure i'm redneck enough to do it lol!
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 09-25-2006, 03:51 PM   #33
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Take a piece of pipe 6-8' or so run a chain inside it(take the hook off one end if need to) then chain it between the two vehicles, this keeps there from being any slack and as you slow down it stops the tow vehicle.just watch for (Z)ing of the pipe or you will kiss bumpers And vise grips on a steering shaft make for a handle to hang onto, just dont try to take a curve a 60mph.LOL
sneakysnake is offline   Reply With Quote
Old 09-25-2006, 04:44 PM   #34
StingRay
StingRay's Avatar
Around here if the towed vehicles not registered and insured you're not legal and have no liability coverage on either vehicle with a tow bar.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 09-25-2006, 10:23 PM   #35
Fred T
Cantankerous Geezer
Fred T's Avatar
Have to agree that if I was towing a vehicle 5 miles I would use a chain or strap. But, since you're not comfortable about that, here's my advice. I've towed everything from garden tractors to semis with a pickup and a chain, have even used a bar a few times.
Towbars are wonderful. Dad and I weren't afraid to use them and go fast. We even pulled a 68 Dodge Polara 200 miles at 80 mph. But we did something most people don't do. Dad drove the towing vehicle, I rode in the vehicle being towed. Hands off the steering wheel, which took some getting used to. But I did run the brakes and turn signals. That way we didn't have to run any wiring for lights, and we had brakes on the towed vehicle, which made it a whole lot easier tow. Most vehicles don't have enough brakes to handle another 2 tons, and you can get in trouble if the brakes get hot.
As for using a pipe and a chain, it's okay for short, slow tows on vehicles without brakes. But I have seen more than one bent pipe. You have to know the lmits.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-19-2007, 11:10 PM   #36
A few 72's
A few 72's's Avatar
Do you think it woud have been a problem to pull either of them 100 miles? Looking at pulling a LWB rolling frame no bed, cab, motor, trans. All freeway 60-65 MPH.
Shan...
A few 72's is offline   Reply With Quote
Old 03-20-2007, 02:20 AM   #37
bad_turbo
turbo enthusiast
bad_turbo's Avatar
does the driveshaft need to be removed before towing a rear wheel drive truck?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 03-20-2007, 02:35 AM   #38
cruisinlow67
^^^^ no just put it in neutral. we towed my 67 10 miles with a tow bar. no problems.
cruisinlow67 is offline   Reply With Quote
Old 03-20-2007, 02:49 AM   #39
CrashEd
72 chevy
CrashEd's Avatar
Fred your dad and my dad must be related LOL!!.
CrashEd is offline   Reply With Quote
Old 03-20-2007, 05:47 AM   #40
Longhorn Man
if the truck is an automatic, and you are going over 25 MPH, and more than 5 miles, yes, you must drop the saft, or you can ruin the tranny.
It'll be spinning with no lube since the pump is friven by the converter, and the converter will be standing still.
Old 03-20-2007, 10:26 PM   #41
texanidiot25
Eat My Rust
texanidiot25's Avatar
Been there, done that.
If you dont have an engine in the towed truck, the front tires will tend to screech on some sharp corners, because the tires turn as the truck swivles on the hitch. And with no weight over the front, the tires are light.
But if your gonna go freeway speed, you gotta take out the drive shaft w/ auto trans. Unless you like buying a new transmission...
texanidiot25 is offline   Reply With Quote
Old 03-21-2007, 12:33 AM   #42
herb101
Used Register
herb101's Avatar
Hmmm - wonder if I should not have done my flat tow September before last. Pheonix to San Antonio with a 1/2 ton 97 Ford shortbed 2wd pulling a 51 Willys Wagon with full running gear. It did help that the Willys had lockout hubs on all 4 corners - ultimate neutral.
Herb
herb101 is offline   Reply With Quote
Old 03-21-2007, 04:54 PM   #43
grayw0lf
So, the next question...
Where is a good place to buy a tow bar?
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 03-21-2007, 05:16 PM   #44
herb101
Used Register
herb101's Avatar
Pep Boys sells the Valley brand unit for about $100 to $125 I think. Most are universal and adjustable and come with brackets and safety chains. You have to install the brackets on the towed vehicle, which can be fun on non-flat bumper faces. I'd stick with the "known" brands of towing gear like Reese, Draw-Tite, Valley, and so forth.
Some vehicles, like Jeeps, have parts available specifically for tow bars. Con-Fer (I think) makes tow bar shackles for Jeeps where the front shackle contains the bar mount - as an example.
Herb
Old 03-21-2007, 06:06 PM   #45
A few 72's
A few 72's's Avatar
Looking at pulling a LWB rolling frame no bed, no cab, no motor, no trans, "No Front Springs", does have steering gear box. All freeway, 60-65 MPH, 100 miles or so.
Can I get away with using the towbar to pull the rolling frame?
Shan...
Last edited by A few 72's; 03-21-2007 at 06:08 PM. Reason: add pic to show how low with out springs.
Old 03-21-2007, 07:02 PM   #46
davidh
davidh's Avatar
Shan...
Think you'd be fine with some springs.
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 03-21-2007, 07:13 PM   #47
flatheadnut0
New Member
Hey Longhorn,
you are right, back n the day, that's all we had except for the "RN" chain and pipe. And yes I am over 60.
Ol Flatheadnut
flatheadnut0 is offline   Reply With Quote
Old 03-21-2007, 08:55 PM   #48
LonghornJeff
EZEKIEL 25:17
LonghornJeff's Avatar
Andy is right they are safe......(87 K5 blazers are best for towing
mine has towed three 67-72 trucks.)
68 CHEVELLE(HORSESHOE)
69 LONGHORN 396
70 NOVA 454(FOR SALE)
71 SWB 307
71 EL CAMINO 383
72 GMC JIMMY 350
87 BLAZER 350 WIW?
http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM
Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists.
The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers...
LonghornJeff is offline   Reply With Quote
Old 03-21-2007, 10:15 PM   #49
Longhorn Man
Yeah jeff, but they handle a little funny when you strap a one ton truck with stiff steering on there though.
Old 03-21-2007, 10:59 PM   #50
skchevota
skchevota's Avatar
I used to tow my jeep all over with a tow bar, it was great. I had it bolted to the jeep insted of that chain strap thing, but for what you are doing, I wouldnt even wory about lights, just put on the flashers, or get someone to follow you.
As for the tow dolly Question, I towed my 70 3/4 ton loaded full, I mean full of stuff on a dolly behind a 26ft ryder moving truck from cali to colorado with no trouble. The weight stamp on the dolly said 3500# but looking how over built the U haul dolly was I figured that I had 3500# on it and probebly 7k total and it was fine. I even had my truck on it backwords, because even with stock tiers and rims the front axle was to wide to fit on the dolly, but the rear is 3" narrower. I even towed a car about 2 miles with a chain once, by my self! dont ask.
skchevota is offline   Reply With Quote
