#26 |
Re: i think ive been had
jooooe it was just the fact that i was told that the truck was all originial and with what i had found so far it was lookin like it was a 305 not a 350. guess i need to learn to look into things a little better.
#27 |
Your friend is right, you don't NEED vacuum advance, but in order for the engine to run most efficiently you should use it.
#28 |
thats what i thought i want to cheak the timing with a light but i dont have a timing tab on the motor and no degree marks on the balancer were would the indecator bolt to on this motor and what about the strip. could i just buy a indecator and bolt it on in a good visable location crank the motor to topdead center on # 1 cylinder and place the srip on lined up on zero?
#29 |
I hate to ask but what makes you think the valves are 2.02 intake and 1.60 exhaust ? To my knowledge they weren't offered on 73 truck engines. Your "pinging" was more likely detonation and backing the timing off a couple of degrees would have certainly improved or eliminated the problem. What were the codes on the pad ? Double valve springs were common and are not a sign of superior valve train. Guide plates are a good thing but they almost certainly aren't stock.
"They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Ben Franklin |
#30 |
the web site he looked the numbers up on had the stock valve size listed i have the numbers ill have to get the out of the truck. what do you think is up with the running now?
#31 | |
#32 |
Your lack of vacuum @the brakes could be due to the cam dynamics.I didn`t know`85 trucks still used 4-bolt mains?Your motor has been "warmed-over" for sure.The 2.02 heads were strickly a high-performance item that didn`t come on trucks,just performance model cars like Super Sports and Vettes.
It sucks that you were lied to.Or,the guy just didn`t know better himself,not unusual.
#33 |
well we got the truck running great took the cam out way to big dont know the size but it had lobes like speed bumps. we went back with a stock 89 iroc tpi 350 cam had one in the garage. does anyone know the specs on that cam. we also went with a holley street dominator intake along with the 650 holley carb this motor is a torque monster now. traction is hard to find now.
