Old 11-11-2006, 08:37 PM   #26
72CSTC5
72CSTC5's Avatar
Re: Gatorbuilt '59
Hey Gatorbuilt, I see you are from Friendswood and I live in Deer Park, was wondering, what panel did you but to repair "behind" the door hinge pocket. Had the owner of the dealership I work at 59 apache dipped and the part came back very thin. I called Brothers trucks and said they do not make that piece. It looks like you are replacing yours. Do you have any better pics of that area.
72CSTC5 is offline   Reply With Quote
Old 11-13-2006, 10:38 AM   #27
GATORBUILT '59
GATORBUILT '59's Avatar
Re: Gatorbuilt '59
There called Rigth or Left Hinge Pillar Pockets. I got them from a place called Bowtie Bits. They ha ve great Sheet Metal Prices. That beat the heck out of LMC. Here is the link http://www.bowtiebits.com/Catalog/sh...1_products.htm
GATORBUILT '59 is offline   Reply With Quote
Old 11-13-2006, 10:42 AM   #28
GATORBUILT '59
Re: Gatorbuilt '59
I do have great additional pictures. Unfortunatly my personal computer is in the shop. And because you asked I will upload additional picures as soon as possible.
Old 11-14-2006, 12:48 AM   #29
Daniel U
Daniel U's Avatar
Re: Gatorbuilt '59
Nice work! Lookin good. Post up those pics!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 11-14-2006, 11:22 PM   #30
pgf545
pgf545's Avatar
Re: Gatorbuilt '59
Gator, Ummmmmm I really don't know any body people in this area. I am terrible at body work so I can't help you there...lol. I am pretty good at most mechanical stuff though...If I can be of assistance let me know.
You might check with 72 CSTC5 I think he does body work and he is over in Deer Park.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 11-27-2006, 10:33 PM   #31
GATORBUILT '59
Re: Gatorbuilt '59
Ok Daniel you asked for pics. so here are some good before and afters. They include repacing the pass. side step. Passenger lower door hinge pillar and pockets. Also cab corners and door bottoms.
Old 11-27-2006, 10:40 PM   #32
GATORBUILT '59
Re: Gatorbuilt '59
After
Old 11-27-2006, 10:43 PM   #33
72CSTC5
72CSTC5's Avatar
Re: Gatorbuilt '59
Dude thanks alot for the link on where to get the parts. Thats exactly what we were looking for. I can not believe Brothers does not carry those parts. They thought I was crazy when I called them on the phone about them. If you need any bodywork help contact me on here.
Old 11-27-2006, 10:47 PM   #34
GATORBUILT '59
Re: Gatorbuilt '59
Cab Corners
Old 11-27-2006, 10:50 PM   #35
72CSTC5
72CSTC5's Avatar
Re: Gatorbuilt '59
Looks good. You do nice work.
Old 11-27-2006, 10:50 PM   #36
GATORBUILT '59
Re: Gatorbuilt '59
Sure no problem, Let me Know if i can help you in the Future.
Old 11-27-2006, 10:55 PM   #37
GATORBUILT '59
Re: Gatorbuilt '59
before Door bottoms
Old 11-27-2006, 11:02 PM   #38
GATORBUILT '59
Re: Gatorbuilt '59
After Door Bottoms
Old 11-27-2006, 11:07 PM   #39
GATORBUILT '59
Re: Gatorbuilt '59
I also had a chance to install the motor mounis and rack n pinion
Old 11-28-2006, 11:19 AM   #40
Daniel U
Daniel U's Avatar
Re: Gatorbuilt '59
Someones been very busy or holding out on pics Looking good. Keep up the straight body repairs.
Old 12-01-2006, 03:56 AM   #41
samcrf450
samcrf450's Avatar
Re: Gatorbuilt '59
Gatorbuilt '59 did you run into any issues with the tail shaft of your tranny being too close, to the frame crossmember just to the back of the cab, for your drive shaft? I put the TCI mustang II kit in as well and was mocking up my motor mounts with the tranny on the back of my motor and it looks like the drive shaft is going to hit if my truck bottoms out ( I am going to c-notch the frame). I actually had to cut quite a bit off of my motor mounts. I was also not clearing the transmisson access panel inside the cab. The transmission was make it pop up. I dont have a drive shaft right now to see if it is going to hit or not. Just thought I would ask. It looks like we are going the same route.
1956 chevy 3100 short bed small window- TCI mustang II with 2" drop spindles, smoothed firewall, CPP brake booster, chevy 10 bolt with disc brakes, c notched.
http://67-72chevytrucks.com/vboard/s...d.php?t=217757
samcrf450 is offline   Reply With Quote
Old 12-01-2006, 10:53 AM   #42
GATORBUILT '59
Re: Gatorbuilt '59
This may Be Tough Advice. But go back and check your measurements given to you in the TCI kit. I noticied that when I mocked up everything on my TCI kit I noticed that the Mustang II Axle center Line not the same as the Original Axle center line. This is for good reason if you look at side views of original front axle trucks. The front wheel seems to be sitting towards the rear of the fender. If you take a closer look at the pictures it even caused me to cut away some of the orginal crossmember that is located at the very front of the frame just to clear the rack-n-pinion.
If you are speaking of the the orignal tranny crossmember, I cut mine out. If the crossmember that you speak of is the one that held the emergency brake cables. My tale shaft comes no where near it and I have a 700R4. If i get a chance I will take a few pictures for you.
Old 12-01-2006, 03:03 PM   #43
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Gatorbuilt '59
Its true about the axle center line, so just to be sure I tacked mine in place and mounted my wheels in tires and a fender and stood back and looked where the wheel was seating in the wheelwell before I welded it complete in. I seen too many clips at shows that the wheels just did not look right.
Kabwe is offline   Reply With Quote
Old 12-01-2006, 04:51 PM   #44
samcrf450
samcrf450's Avatar
Re: Gatorbuilt '59
I have already mounted my fenders back on and the wheels are dead on. That is not problem. I drilled my tranny crossmember out it is the one behind that that I am worried about. Yeah if you could take some pics I would appreciate it. I just need to get a drive shaft and put it through the range of motion. I am probably worrying about nothing I just dont want to weld those motor mounts in until I know everything is straight.
Old 12-02-2006, 08:55 PM   #45
GATORBUILT '59
Re: Gatorbuilt '59
Ok. here are the pis of trans tail shaft. remember this is the tail of a 700R4.
Old 12-04-2006, 12:41 PM   #46
samcrf450
samcrf450's Avatar
Re: Gatorbuilt '59
thanks. Yeah I just got everything mounted up and it looks about the same as yours. I just got a drive shaft and slipped it on and it is not going to hit the front member at all.
Old 12-05-2006, 08:37 AM   #47
GATORBUILT '59
Re: Gatorbuilt '59
Great I am glad everything worked out.
Old 12-10-2006, 09:53 PM   #48
GATORBUILT '59
Re: Gatorbuilt '59
Well I guess I can stop NOW!!!
Old 12-10-2006, 11:18 PM   #49
samcrf450
samcrf450's Avatar
Re: Gatorbuilt '59
So does your trans x-member interfere with your brake booster bottom bracket?
Old 12-10-2006, 11:32 PM   #50
samcrf450
samcrf450's Avatar
Re: Gatorbuilt '59
I still need to buy my booster I am going to go with CPP for it. They have a killer deal right now for 249. I just need to convince the wife. But by the looks of yours it looks like it might be a tight fit.
