Old 10-20-2006, 10:29 AM   #26
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: 0.060 Over
Originally Posted by Ole Blue 68 View Post
I think the machinist was giving you good advice. Suppose you had to have the block machined again? You'd still have room to work with a .030 while a .060 wouldn't leave you much at all and you'd probably be shopping for a new block.
Depends. True, boring .060 just to go .060 doesn't make much sense, but if the block had already been bored .030 at some point before, and can be cleaned up by going another .030, there should be no problem, and it would just further extend the life of the block.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-20-2006, 10:31 AM   #27
67 cst swb
67 cst swb's Avatar
Re: 0.060 Over
If your Machine Shop has already bored the block to the .060 over pistons, you may not be able to change pistons now, they bore/finish hone the cylinder to the pistons, if your concerned with cash... just stay on the path your on... the cam, heads, & rear gears are what (in my opinion) really make up how good a truck runs... I've had stock component 327's with decent cam (pretty much the largest cam I could run with stock valve springs) and 3.73 gears with stock 041x heads (I can elaborate on that if you need me to) then use a 2000 stall convertor (600-800 over stock stall, some advertise differently). If your replacing a worn out stock motor, you'll be pleased with the performance and the price tag. And you won't have to change horses mid-stream...
PM me if you have questions...
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 10-20-2006, 10:44 AM   #28
CMars45000
CMars45000's Avatar
Re: 0.060 Over
Use an after market crank and some decent 6.0" rods and some nice hypereutectic pistons and youi will be set...
I don't know that I have ever seen pistons with a compression height to work with 3.75" stoke and 5.7" rods...
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 10-20-2006, 11:53 AM   #29
BarryB
BarryB's Avatar
Re: 0.060 Over
I have a set of pistons that you are talking about. The wrist pin hole is moved to compensate for the difference. They are Keith Blacks .
BarryB is offline   Reply With Quote
Old 10-20-2006, 12:12 PM   #30
Ole Blue 68
Ole Blue 68's Avatar
Re: 0.060 Over
Right, I was talking about if you had a choice between .030 and .060, you'd want to go .030.
Ole Blue 68 is offline   Reply With Quote
Old 10-20-2006, 03:52 PM   #31
glock35ipsc
Re: 0.060 Over
10-4!
Bob
Old 10-20-2006, 08:59 PM   #32
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 0.060 Over
one thing mentioned up there isn't acurate... a 400 with a 350 crank isn't a 383, that would be a 377, high RPM motor.
Old 10-20-2006, 09:32 PM   #33
glock35ipsc
Re: 0.060 Over
Check my post #11 for all combos.
Bob
Old 10-20-2006, 10:41 PM   #34
69face
69face's Avatar
Re: 0.060 Over
scoggin dickey sells a very very inexpensive kit for you. always keep the phase " there is no replacement for displacement!" stroke on!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 10-22-2006, 02:36 PM   #35
chevymad
Re: 0.060 Over
One more thing to the mix. If you use aftermarket rods get capscrew style rods instead of regular bolt type. There won't nearly be as much block clearancing required if any, and you can run a normal cam instead of a small base circle.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
