Old 10-25-2006, 10:19 PM   #26
orange-c10
Re: timing mark way off the scale???
ya thats what im thinking too. does anyone know where i can get some edelbrock intake gaskets without having to order em. or can i use the stock.
orange-c10 is offline   Reply With Quote
Old 10-26-2006, 12:53 AM   #27
Billla
Billla's Avatar
The Performer has an exhaust crossover - so any good quality gasket set will work. If you can't get FelPro, the NAPA stuff is pretty darn good.
May be telling you stuff you already know, but be sure to run a 1/8" bead of RTV around the coolant passages and use thread sealant as appropriate on the bolts. It's easiest to have the engine at compression TDC on #1; that way you can just point the rotor at #1 and have a timing setting that will let you get it started.
Billla is offline   Reply With Quote
Old 10-27-2006, 09:42 PM   #28
orange-c10
well. checked timing mark and it lines up close to zero at the top of the compression stroke. removed the manifold and found something that made me feel like a retard. the gaskets i installed were the wrong ones. they werent cut out for the exhaust crossover. cant believe i didnt notice when i put them on. everything is reinstalled but i have to wait till tomorrow to start it and time it. dont know if that was my problem or not.
Old 10-27-2006, 09:49 PM   #29
jake60
That will cause your problem. Been there done that.
"Common sense is very uncommon" Rudyard Kipling
jake60 is offline   Reply With Quote
Old 10-27-2006, 11:51 PM   #30
Billla
Billla's Avatar
Sounds like you nailed it; let us know. Always remember when you're troubleshooting to let folks know about any recent changes
Old 10-28-2006, 04:13 PM   #31
orange-c10
started up the truck today and set the timing to 4 btdc. truck runs great. no pings and no hesitation. thanks to everyone for their help. this website is a great resource.
Old 10-28-2006, 09:42 PM   #32
Billla
Billla's Avatar
Congrats! It's still worth going through the tuning process to get the max HP from what you've got.
