Old 11-06-2006, 04:17 PM   #26
67chevemall
67chevemall's Avatar
Re: generater light
Grounds are always a suspect! Try the cluster ground engine ground check em all.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 11-06-2006, 04:20 PM   #27
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: generater light
Is your belt in good shape and tight? Ive seen the light glow from a loose belt.
sneakysnake is offline   Reply With Quote
Old 11-07-2006, 01:37 PM   #28
caseychoptop
caseychoptop's Avatar
Re: generater light
not checked the belt yet, good point will check that one, checked all the ground cables i can see but im putting new one in to be on the safe side
caseychoptop is offline   Reply With Quote
Old 11-07-2006, 02:36 PM   #29
dave2953
Dave's not here, man
dave2953's Avatar
Re: generater light
You could have a wire grounding out on something. I wasn't using my factory temp. sending unit wire and it was ground out on the block, causing the temp light to stay on continuously. Check all the wiring to the alternator and makes sure none are skint/broken.
As a footnote, how far are you from Kings Lynn? I used to live near RAF Lakenheath.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
