11-16-2006, 02:10 PM | #26 | |
Re: What headers are you using for your BIG BLOCK?????
11-16-2006, 02:28 PM | #27 | |
I'm thinking the same thing. It's just a decision of whether I want to buy local, which I may spend about the same once POL adds in their shipping for their items. I do like the quality and unique look of the POL brackets, though. I'll have to mull over this one for a while. Jesse
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) |
11-16-2006, 02:41 PM | #28 | |
11-16-2006, 04:47 PM | #29 |
computer illiterate
[QUOTE=novajess1972;1886818]I'm thinking the same thing. It's just a decision of whether I want to buy local, which I may spend about the same once POL adds in their shipping for their items. I do like the quality and unique look of the POL brackets, though. I'll have to mull over this one for a while.
Jesse[/QUOTE/] i have a setof of 68-71 mounts for 100 shipped if anyones interested
72 2wd blazer 72 swb 4x4 |
11-16-2006, 05:13 PM | #30 | |
[QUOTE=meathead95;1887017]
Thanks anyway!! Jesse
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) Last edited by novajess1972; 11-16-2006 at 05:14 PM. |
11-16-2006, 07:32 PM | #31 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=122645 Last edited by ratrod67; 11-16-2006 at 07:55 PM. Reason: Forgot link....Duhh!! |
11-16-2006, 07:47 PM | #32 |
Active Member
Take a look at the motor mounts for the 68-71 BB there are like $70 each side. so $80 each side for stands = 160 then mounts 70 each side =140
$300.00 just in mounts for a BB. Kind of scarry. Im in the same boat. I would really like some 72 BB stands but big bucks if you can find them. Jack |
11-17-2006, 08:36 AM | #33 |
[QUOTE=novajess1972;1887053]what kind of clearance do u have on your motor front and rear and which holes are u using front or rear
11-17-2006, 08:38 AM | #34 |
ratrod67 what kind of clearance do u have in the front of ypur bbc and did u use front or rear mounting holes
11-17-2006, 03:55 PM | #35 | |
[QUOTE=prostreet1967;1889093]
By the way...first time using Outback, and their facility is really nice. It's a very personable Mom & Pop outfit with great people, and tons of neat products and body parts. I highly recommend them. Number is 281-350-9072. Jesse
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) Last edited by novajess1972; 11-17-2006 at 03:56 PM. |
11-17-2006, 04:00 PM | #36 | |
action, the gentleman at Outback verified that existing mounts will work, but there are correct ones out there if you want everything to be perfect. With my wife-imposed truck budget, I have to get the necessities and work from there. If they work, I don't buy anything else. If I can prove to the wife that I MUST have the others, then we argue, fuss, fight, throw furniture....then I get the correct ones . I will let you all know how they work out. Jesse
11-17-2006, 05:46 PM | #37 |
computer illiterate
i forgot to add the ones i offered are nos
11-17-2006, 06:48 PM | #38 |
Active Member
I just wasn't sure how the small block MM would fit sense the BB mounts have the big hole w/rubber on back side. I hope it works as I think it is terrible to have to pay 65-70 for each MM.
Let us Know how it works. Jack |
11-17-2006, 07:50 PM | #39 |
11-17-2006, 09:49 PM | #40 |
18 Till I Die
Ok MY 2 Cents I guess.
I have a 69 with a 454 LS7. I am using 69 BB stands with small block mounts. I dont have the BB rubber backing, I used heavy square plate with grade 8 bolts. I wont come out. I am looking at replacing them with poly someday but they are GM NOS mounts so they should last awhile. My Headers are Hooker Super Comps and they fit nice. I pulled them out thru the bottom and had them ceramic coated. I had no problems with fit they slide in and out nice. They are a little close to the stock starter so I installed a zero heat sink Powermaster(Problem solved)
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
11-18-2006, 03:07 AM | #41 |
Active Member
Nice looking headers, How low do they hang under the truck?
Thanks Jack |
11-18-2006, 11:48 AM | #42 |
those are sweet!
Daily Driver:
383 sbc Shaved. lowerd |
11-18-2006, 10:38 PM | #43 |
"Trucks with Class"
Meathead95:
I would like those BB MM. I assume if NOS that they are not installed? In original GM boxes? Pics? I tried to PM you, but no go. Could you email me: frankeham@comcast.net Thanks, Frank |
11-19-2006, 12:16 PM | #44 |
computer illiterate
they are not in the origional boxes i bought them from a board member here off of ebay . i believe they still have the stickers on them though. ill check today and get a pic.
11-20-2006, 08:38 AM | #45 |
my truck is a 67 im using the front holes and the crank pulley won't go on its hitting the front crossmember near radiator core support. any suggestions should i put a round tube crossmember like djracer did to clear the pulleys? don't have enough room to go to the back holes motor will hit firewall.
11-20-2006, 09:25 AM | #46 |
its hitting here
11-20-2006, 11:39 AM | #47 | |
Not sure about the crank pulley hitting the front crossmember, as I haven't reinstalled them yet, but it does't look as though I will have any problems. But one problem I did encounter is that the BB is pushing the driveshaft back farther, so now I have to have it shortened (sigh of frustration). I will keep you posted. Jesse
01-04-2007, 09:02 PM | #48 |
01-04-2007, 10:28 PM | #49 |
Ive got hooker comps for a chevelle on my 396. Bolted right up & dont touch a thing. They tuck up in the frame nice too...
01-05-2007, 01:19 AM | #50 |
Mine is damded close. I just added an aluminum pulley and it now comes within 1/4" of hitting. The aluminum pulley has 3 grooves and the old pulley had 2 grooves and left plenty of room. The last owner ground out the area you have highlighted but I'm not sure why.
On a side note does anyone make a replacement for the crossmember? Thanks, Whit |
