Old 11-17-2006, 10:13 PM   #26
84_4x4
84_4x4's Avatar
Re: my FREE FREE GMC 3/4 ton 4X4, did I mention FREE!!
Originally Posted by 70rs/ss View Post
The plate is there, just no year indication (I am mostly a chevy guy and the year is stamped there) I hauled it to the in-laws for disassembly over the turkey day holiday, I can get the numbers then. The front looks like a dana 44, closed knuckle means at the pivot points on the front axel you can't see the inner axle and on a open you can the closed axle rembles a big metal ball on the pivot part of the axle (this is for the 67-69 on a chevy) so I was guessing 69 with a newer 14 rear? I am using it anyway, I just hope I do not need to swap gears to match up the ratio!
Oh BTW the guy walked away!! (I was figuring he was drunk) but we have open range with cows, horses, sheep, deer, and an occasional elk so you never know!!
look at the 8th didget and that will tell you its a 70 sumthin like if its a 3 the its a 73 if its a 6 its a 76 you get where im goin
84_4x4 is offline   Reply With Quote
Old 11-17-2006, 11:19 PM   #27
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Actually, since it is a GMC of unknown year, he'll need to post more than that. GMC chainged there VIN layout a few times... almost year to year, and actually in some years there was more than one way of doing it.
Old 11-17-2006, 11:21 PM   #28
70rs/ss
70rs/ss's Avatar
Originally Posted by trkklr77 View Post
no d60's except in jeep gladiators, 4x4 3/4-1t was a d44 or a napco.
the rear is either a d60 or eaton, you said it had a smooth rear cover, 14b has a diamond shape with a squared off peak.
if its a th350 auto it has 205 t case.
hopefuly that front bumper is still straight cause it looks bad ass.
what winch?
No I said the rear is not smooth, so it is a 14 bolt, maybe a 60? Definately not an eaton. There is a winch hiding behind the carnage!! It is a 4-speed, but still hoping for a 205 (I say hoping cause I took it to the in-laws for storage and I didn't check it) The bumper is perfect (the mounts are a little bent, but I can cut them off and reweld new ones onto it) The rear bumper matches the front and they are made of like 1/4" thick steel!! I believe those will go on the K5. I'll take lots of picts as I take it apart, man the passenger's side framerail is wrapped up around the motor, so I am planning to torch it apart!!
70rs/ss is offline   Reply With Quote
Old 11-17-2006, 11:27 PM   #29
70rs/ss
70rs/ss's Avatar
What do I need to look for? The tag inside the driver's door is there but not very long, is there anything else? I won't be near it till Wed of next week, but any ideas of where to look to verify the year? It really doesn't make or break it, just curious!! I think I'll still keep it!!
Old 11-18-2006, 12:56 PM   #30
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
i was just rereading the post and relized that i miss read the cover part, a d60 cover is almost identical to a d44 just bigger.
i see the winch but which winch is it?
is it divorced or a mated t case? divorced is definatly a rocwell 221, mated could be either. 205 will have a blue rectangular id plate between the frount out put and the input of the tcase.
trkklr77 is offline   Reply With Quote
Old 11-20-2006, 04:20 PM   #31
70rs/ss
70rs/ss's Avatar
It is a warn winch, and I'll be under the truck in a day or two so I can give better info. I hope to pull everything off of it over turkey day (5 day weekend for me) and have most if not all onto the 68 short fleet 4X4 3/4ton say that fast 2-3 times!!
