Old 11-28-2006, 07:36 PM   #26
jimmydean
jimmydean's Avatar
Re: The front is done!
The tank also has the most fittings. I tried to use as few fittings as possible, but the tank had all sorts of random sizes, so I had to use reduction bushings and stuff. I used a lot of thread sealer, but I'm sure there are still spots.
I will spend some time this weekend getting the back done and chasing leaks.
jimmydean is offline   Reply With Quote
Old 11-28-2006, 07:51 PM   #27
pharcyde05
pharcyde05's Avatar
leaks always happen if there small like over a 12 hour period i wouldent worry about them they come and go i have had a leak that will happen one day then not happen again for months and they change with the weather too its funn how temp can make air do funny things
hope you hit the road soon
pharcyde05 is offline   Reply With Quote
Old 11-28-2006, 07:56 PM   #28
jimmydean
jimmydean's Avatar
I figured it would leak a little. I just don't want to have to wait for the tank to fill every morning while I piss the neighbors off. I know the lady accross the street asked my wife "is it going to be as loud as it was when he's done?"
She doesn't know about the stereo I am building next
Old 11-28-2006, 08:45 PM   #29
pharcyde05
pharcyde05's Avatar
that is true you are probley loosing too much over night i know in the winter i lose about 10 psi over night and about 5 psi in the summer time
if you can get it down to that your neighbors sholdent complain i have some shut off valves and some check valve in certinplaces that seems to help i dont get and bled back to my compressor head with a check vave at my tank inlet so onec its in the tank it stays there and you can put them at the out side of the fill valve and that will also stop blead back from bags if tank press gets low and at outlet lines on tank that way if you have any leaks in a line or at valves you wont lose tank pressure
Old 11-29-2006, 01:20 PM   #30
1lowdiesel
1lowdiesel's Avatar
run legris fittings and you won't have to worry about leaks even with a crooked line.
1lowdiesel is offline   Reply With Quote
Old 11-29-2006, 08:45 PM   #31
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Legris/Transair right? I'm going to look at an airport job tomorrow that one of my commercial plumbers did in all Transair piping for their compressed air system. They make some badass stuff but I didn't know they had fittings available for our systems.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
