Old 12-01-2006, 07:22 AM   #26
dwaite72lnghrn
Re: I am so confused. Please help.
First verify the rear end. I thought most 3/4 tons had a H052 or dana 60 in them. H052 pretty much eliminates a gear change. Dana 60 will give you more options if you are thinking swapping gears. And anytime you go 65mph the truck is a big brick being pushed through the wind so MPG will drop because of the resistance. 14mpg could be a target, I would go with taller tires. This is the cheapest way to drop rpms. Get a vacuum gauge and use it to keep vacuum up just a little pressure change on the gas pedal will give a big change in vacuum (fuel economy) with a little drop in speed. Remember to correct for the tire size with your speed and mpg calculations. I have heard of people making changes to tires or gears and never change the speedo gear and said the MPG was the same, until they added the 15% change in miles driven.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 12-01-2006, 11:01 AM   #27
chadvicki
I do have 31.5" tires and my speedo is off by about 10mph. So this could effect my milage on the dial? Would I be less or more on the mileage do you think?
Where does one go to get their speedo calibrated?
Thanks,
Chad
chadvicki is offline   Reply With Quote
