Old 12-25-2006, 05:30 AM   #26
Daniel U
Daniel U's Avatar
Re: My '51 Project
You are literally "in the weeds" low! I like that look man. I personally think if you like it that low, you'll have to bag it. I, myself, will be using the drop springs on my Mudstane II front end.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 12-25-2006, 09:46 AM   #27
Hart_Rod
Hart_Rod's Avatar
Re: My '51 Project
Originally Posted by Daniel U View Post
I like the plate an vintage frame! Are you going to "rat rod" it or go for the finished look? Sounds like between the suspension and frame work you have a good size budget! It all adss up quick. I'm up to $25k without paint, interior or sound!
Daniel - that makes me not feel so crazy about asking $39K for mine. People don't realize how much you can tie up any these things. Even at that price, I'm probably only making about a nickel an hour for my labor!
SteveHSD, do you have any picture of the front end set up on your old project? A friend of mine is building a chassis from scratch similar to that and any pics we be a big help. Thanks,
Rob
Hart_Rod is offline   Reply With Quote
Old 12-25-2006, 10:58 AM   #28
Hart_Rod
Hart_Rod's Avatar
Re: My '51 Project
Here's a picture of my 48 with Heidt's Mustang II crossmember, stock spindles and 25" tires. I don't know that I would want it much lower, especially if you drive it a lot. The second pictures is my 52, Mustang II crossmember (TCI??) bagged, 2 1/2 dropped spindles -- definitely will not be an every day driver.
Rob
Old 12-25-2006, 03:02 PM   #29
56chevy1300
56chevy1300's Avatar
Re: My '51 Project
Thanks for the pics...keep em coming!
56chevy1300 is offline   Reply With Quote
Old 12-25-2006, 07:00 PM   #30
stevehsd
stevehsd's Avatar
Re: My '51 Project
No suspension at all right now.
Just the stock frame laying on original axles.
I plan on Must II front
4 link rear , bagged.
I guess this is as low as I can go with a stock bed.
About 4 inches off the ground at the floorboard.
51 3100 build thread http://67-72chevytrucks.com/vboard/s...light=stevehsd
77 FLH
stevehsd is offline   Reply With Quote
Old 12-26-2006, 04:16 AM   #31
stevehsd
stevehsd's Avatar
Re: My '51 Project
HartRod
I mistook your suspension question
I Had to cut the frame horns off the 29
Had some split wishbones and attached them
tried some coil over springs but conflicted with headlights
and didn't look right
just chained it up to sell it
77 FLH
Old 12-26-2006, 10:00 AM   #32
Hart_Rod
Hart_Rod's Avatar
Re: My '51 Project
Originally Posted by stevehsd View Post
HartRod
wanted to spring it like tke this one.
Thanks for the photo, do you have any of yours before you sold it?
R
Old 01-01-2007, 12:48 PM   #34
Daniel U
Daniel U's Avatar
Re: My '51 Project
That one loooks like some fast/cheap fun!
Old 02-22-2007, 03:31 AM   #35
stevehsd
stevehsd's Avatar
Re: My '51 Project
got the rear end changed today
chevy 10 bolt
77 FLH
Old 02-22-2007, 04:27 PM   #36
Daniel U
Daniel U's Avatar
Re: My '51 Project
What are you using for engine/trans?
Old 04-06-2007, 10:23 PM   #37
stevehsd
stevehsd's Avatar
Re: My '51 Project
Ordered the parts pkg from Zig's
Must II with bags
4 Bar Rear with bags (triangulated)
firewall brake booster
brake lines
Next week it's off to the shop!
77 FLH
Old 04-06-2007, 10:24 PM   #38
stevehsd
stevehsd's Avatar
Re: My '51 Project
700R4
350 I guess.
77 FLH
Old 04-07-2007, 01:10 PM   #39
Sam59
Flat Broke
Re: My '51 Project
i dig how it sits with no suspension looking good keep it up!
Sam59 is offline   Reply With Quote
Old 04-08-2007, 12:42 AM   #40
cajundragger
Re: My '51 Project
how low you going? Im going to the 'board on 20's and its at alot of work....basically too much.
Either way it looks good, ask me questions if you have any, Im pretty sure I'll know them because I paved the road your about to start going down...
cajundragger is offline   Reply With Quote
Old 04-10-2007, 08:30 PM   #41
stevehsd
stevehsd's Avatar
Re: My '51 Project
I wanted it to go to the boards but I'm thinking about keeping the bed stock.
So with 15 rally wheels and pumpkin to the bed I'm about 3-4 inches off the boards. I guess I could air out the wheels if I want it any lower, easier than dealing with the bed. I got the parts today, Heidt's crossmember, disks, brake booster but the rear is a straight TCI 4 link rather than the triangulated. What do you guys think? What is the advantage of each? Should I return it?
77 FLH
Old 04-11-2007, 12:25 PM   #42
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: My '51 Project
a triangulated 4-link will bind some in corners, but rubber bushings can give it enough compliance to deal with that. if set up properly you can put the instant center (the imaginary point where the upper and lower links meet when looking from the side of the vehicle) right on the anti-squat/anti-rise line so the rear of the vehicle will remain still when launching and not waste power moving the suspension. a longer SVSA (side-view swing arm, the distance the instant center is from the axle) will result in less pinion angle change and generally better ride/handling characteristics. it will not require a lateral restraint if the converging links are set close to 45 degrees
a four bar has the bars parallel in side view and plan view (view from the top) and will require some sort of lateral restraint like a panhard bar or watts link. (not necessarily a bad thing) there is generally no change in pinion angle if the links are the same length. these tend to squat on launch, but if you angle them up some, you can eliminate some of the squat. i have read that if you mount the right side frame bracket higher than the left that it can help launch characteristics also (dynamic rear tire load equalizing)
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 04-11-2007, 12:31 PM   #43
1-ton of fun
polishing a turd
Re: My '51 Project
here is some reading here to explain some of this further:
http://home.earthlink.net/~whshope/id8.html
i would definitely suggest to build some adjustability in the system so you can dial it in once the truck is running and driving.
Old 04-13-2007, 04:46 AM   #44
stevehsd
stevehsd's Avatar
Re: My '51 Project
Off to the shop
77 FLH
Old 04-13-2007, 11:51 PM   #45
stevehsd
stevehsd's Avatar
Re: My '51 Project
Heidt's MustII installed
77 FLH
Old 04-14-2007, 12:43 AM   #46
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
Re: My '51 Project
looks great so far....keep up with the pics pls!
tiggerstoy is offline   Reply With Quote
Old 04-14-2007, 11:43 AM   #47
Daniel U
Daniel U's Avatar
Re: My '51 Project
Good work!
Old 04-20-2007, 01:32 AM   #48
stevehsd
stevehsd's Avatar
Re: My '51 Project
The rear end is boxed now, awaiting suspension.
I'm reconsidering the lowered height
I've gone this far why not 3 1/2 " more to get the boards on the ground.
I guess I'll deal with the bed height later.
Here's the bad side of the truck that never gets photo'd
It could use another 3 1/2" drop!
77 FLH
Old 04-22-2007, 12:23 AM   #49
stevehsd
stevehsd's Avatar
Re: My '51 Project
Here's the TCI 4 link installed, I think I'll add a 3 1/2" c notch next.
77 FLH
Old 04-22-2007, 10:55 PM   #50
pgf545
pgf545's Avatar
Re: My '51 Project
Looks great Steve. Keep up the good work. Should be rolling in no time.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
