01-27-2008, 12:06 PM | #26 |
67-72 parts collector,…
Re: crew cab headliner board ?
Not a problem at all. If it wasn't for this board,... and OJOE,... I wouldn't be collecting parts to build my own. (this board is WELL WORTH the $25 bucks it costs to be a supporting member!)
04-07-2008, 08:41 AM | #27 |
Bringing this back from the dead.
I have been sitting on this one for a while - 1987 Chevy shorty: I have been hoarding parts for quite some time. 3"/5" drop kit (springs/flip kit) Chrome 15x8 rally rims Brand new OEM GMC center caps for rally rims Hidden hitch Roll pan with flip down bracket for the hidden hitch Charcoal interior (for regular cab but have light gray Suburban/Crew specific headliner trim pieces) including near perfect dash-pad Brand new OEM Silverado door panels for manual windows and locks Some other items I am not remembering right now So I brought home this '87 GMC crew cab today: The bed is rough as is the front clip and the interior. Runs decent even though it has been sitting for a few years and the price was right. But as I said earlier in this thread, I would sacrifice my '86 GMC long bed for the right crew cab project. Looks like I will be making that sacrifice! It will be a while before I get this moving but will probably be asking questions here. First questions: OJOE has been using 1-ton frames but the crew I bought is a 3/4 ton. Will the 3/4 ton frame mate together with the 1/2 ton rear the same way as the 1-ton? Is converting the 3/4 ton front suspension to the half ton as simple as just swapping spindles/brakes? Thanks in advance!
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
04-07-2008, 12:05 PM | #28 |
Luv the Crewcabs
So u Decided against going 4x4 with Your's??, I also Continue Gathering Part's for the 4x4 that i want to do..............
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
04-07-2008, 04:16 PM | #29 |
Ok, I have read this twice and I have a question.
Is the 1 ton frame wider than the 1/2t? are you putting the rear half in a bind by slidding it into the front half of the 1t? Thanks -Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
04-07-2008, 05:40 PM | #30 |
69fatmotor
kevin1970, the frames on the crewcab 1 ton and 3/4 ton are same. manimal , the 1 ton and 1/2 ton frames are the same width. there is some flex in the two frames so there is no binding. the two frames slide together with little effort. here is the build thread for joe's truck http://67-72chevytrucks.com/vboard/s...d.php?t=272118
04-07-2008, 06:41 PM | #31 | |
I have had that shorty in my backyard for around two years. I have an '06 regular cab shorty and while that is great for commuting, it isn't so great for going places. I figured if I am going to put the time and effort into a short bed, it might as well be something different that what I have now and have some sort of usability too. Plus this gives me two things which may not make any sense to anyone else. First, for whatever reason, I have a preference for GMC's. No good reason for it, just have a thing. The green one is a chev but the crew is an actual GMC. My goal with the green truck was to try to make it a complete Craigslist build. Granted I am not building a show truck. But so far, every part I have bought for this project has been from the pages of CL. Again, no good reason? And after buying this one, I have told myself no more looking on CL for a while; I keep spending too much money...
04-07-2008, 07:06 PM | #32 |
Luv the Crewcabs
All Make's Sence, Are you going to Start a Build Thread for it?? Congrat's on Finding Your Part's & am Looking Forward to Following your Journey............
Rick
04-08-2008, 01:31 AM | #33 | |
I know you are/were planning a short-stepper 4x4. I have an '85 GMC swb 4x4 in my back yard that I have to get rid of ASAP to make room. It is bent up on the frame horns but everything from around the engine back is fine. If you could think of a way to get this to you I would be more than happy to give it to you? It is a rolling frame (no bed/cab) right now. If it were possible to remove the rear-axle and cut off the frame were needed under the cab I could put the frame section on a big pallet and ship it to you (you pay shipping). Maybe you already have the rear frame section you need though? Anyways, just a thought. Would rather get this to someone with a need than take it to the scrappers. PM if you think something like this would work. So about the front suspension, I am under the impression that just a spindle swap and I have 1/2 ton front suspension? Anyone confirm or refute this?
04-08-2008, 01:39 AM | #34 | |
Crew Cut
you will need to swap out a-frames and spindles the ball joints on 1 ton will not fit the 1/2 ton. good luck on your project
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
04-08-2008, 01:41 AM | #35 |
Crew Cut
we talked about everything, but i still dont have a headliner. lol
04-08-2008, 04:43 AM | #36 |
Thats actually pretty funny!
I'll keep paying attention as I will need one too.
04-08-2008, 05:14 PM | #37 |
Luv the Crewcabs
Thanks for the Offer, I've got the rear Section allready. It actually slide's together Pretty easily, I Did it by myself just using a Ratchet strap to pull it together.................
Here is a Pic for you......... Rick Some one else on a Post was looking for a 4x4 frame section in the Washington area, I will see if i can find that post & Pm you the info, Maybe you can help him out with your Frame.......... Thanks Again for the Offer that was Pretty Kool of You
04-09-2008, 06:53 AM | #38 | |
-Lance
04-11-2008, 04:09 AM | #39 |
Crew Cut
toomanytoyz, you know you will need to cut the top lip off the 1/2 ton frame so when the 2 frames meet they will be even on the top and all of your factory holes will line up in both frames. then you can bolt your cab mounts on, the bolts will go thru both frames and cab mounts.good luck joe
05-01-2008, 09:11 AM | #40 |
Luv the Crewcabs
Joe,
Thanks for the Reminder, I wondered why the hole's were not lining up Quite right............ kevinr1970, Have u Started a Build Thread Yet, ust want to make sure i id't miss it if you Have? Thanks, Rick
05-01-2008, 05:08 PM | #41 | |
My goal is to have it drivable with the short bed by the weekend after Labor Day. We go with my girlfriends parents to Seaside, OR for a car show every year. I won't be showing (nothing newer than 1960 anyways) but would like to drive it down. Provided gas isn't $5 a gallon...
05-01-2008, 05:27 PM | #42 |
Luv the Crewcabs
Thanks for the Update, On the Subject of Gas i Just went into Town & it was at $3.75 here............
Thanks, Rick
06-13-2008, 01:47 AM | #43 | |
Luv the Crewcabs
Rick
06-13-2008, 09:09 AM | #44 |
I'm just glad to be here!
Back when I had my CrewCab, I had an upholstery shop do the headliner for me. They just glued on some foam padding then glued on the material to that. It was molded to the shape of the roof panel. Looked good.
Just a thought... Now all of you have made me want to build a CCSWB.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
06-13-2008, 03:36 PM | #45 | |
Just do it. Ya' know ya' want too...
01-02-2009, 12:10 AM | #46 |
Luv the Crewcabs
ttt.............
ojoe wandering if you ever found a source for the Headliner Board??? Rick
01-02-2009, 12:41 AM | #47 |
yeller
I have a HL board set from a 90 Suburban you could have for free and try to make work if you wanted...but shipping/boxing it up would be a PITA!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
01-02-2009, 10:38 AM | #48 |
69fatmotor
he did finally find one in a one ton. he's working on getting the interior done know.
02-22-2009, 11:04 PM | #49 |
Luv the Crewcabs
Would it be Possible to Make this a Sticky Thread or Better Yet a faq? I know that a lot of other members have used ojoe's method to make a Short bed Crew, He outlines all info needed for the Conversion ................
ojoe, Again Many Thanks go out for Sharing all the info with the Board............ Rick
06-19-2009, 08:59 PM | #50 |
Luv the Crewcabs
ttt
A couple of members have pm'ed me for info on my Crew Build & I Refer them to this Thread. Great Info for anyone considering a Crew Shorty....... Thanks Again for the Info ojoe.......... Rick
