Old 12-26-2006, 04:06 AM   #26
454_72_4X4
454_72_4X4's Avatar
Re: 72 GMC - Engine hitting firewall...need advice
Here's mine.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-26-2006, 08:51 AM   #27
Troy-Built
Try the simple things first. Like what was said before look at your cab mounts. It doesn't take much of a drop in the bushings to cause your problem. Also, look at your transfer case mounts they are usually smashed down from all of the weight over the years. Put some polyurethane transmission mounts in place of the old ones and see what that does. If you haven't replaced them already I am sure it needs it. Cheap and easy fix.
69 Chevelle SS 375/396 TKO 600
71 Suburban 3/4 4x4 402 5-speed (project)
68 chevy C10 shortbed 327 5-speed (project)
72 Blazer 4x4 400 4-speed (wifes project)
Numerous 67-72 parts trucks
Troy-Built is offline   Reply With Quote
Old 12-29-2006, 11:42 PM   #28
ducmons
ducmons's Avatar
i got sick, so I haven't been able to work on it.
here is where its touching. Thanks to all for the advice.
ducmons is offline   Reply With Quote
Old 12-30-2006, 08:58 AM   #29
68C15
blood type; Retumbo
68C15's Avatar
if you are careful you can remove the valve covers and rear rockers. lay rags over the heads and use the 2 hammer method of massaging the firewall.
68C15 is offline   Reply With Quote
Old 12-30-2006, 11:34 AM   #30
chevy71super
The main cluprit is the tall valve covers. I have a set on my 71 4X4 and they barely clear. I can't stick my finger between the cover and the firewall and the difference between mine and yours is the corners are more rounded on mine. Your valve covers look great but the easiest solution is to find ones that clear.
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
