Old 01-05-2007, 09:05 PM   #26
1bad chevy
1bad chevy's Avatar
Re: New guy here
all i got to say up here in vermont is nice truck
1bad chevy is offline   Reply With Quote
Old 01-05-2007, 09:56 PM   #27
cgoodwin
cgoodwin's Avatar
Re: New guy here
Thanks 1 bad chevy.
cgoodwin is offline   Reply With Quote
Old 01-05-2007, 10:22 PM   #28
Green Machine
Green Machine's Avatar
Re: New guy here
Welcome from sunny Iowa..... Tranny ratio, I'd get a ratio adapter if needed as mentioned, those three speeds have to come clear apart to change gear on tailshaft otherwise. Gas smell - may need new filler cap, common leak problem on these, and I ususlly don't fill much past 3/4 tank unless on long trip.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 01-05-2007, 10:26 PM   #29
cgoodwin
cgoodwin's Avatar
Re: New guy here
thanks green machine.
any idea where to get the ratio adaptor for the tranny?
Old 01-05-2007, 11:17 PM   #30
FarmTruk
In Memoriam...
FarmTruk's Avatar
Re: New guy here
Originally Posted by cgoodwin View Post
I plan on lower it. I've always heard pick your wheels first then lower it. Haven't picked the wheels yet, so I'm just adding front and rear sway bars for now. I just don't want that mini truck bouncy ride, so I'll shop around for the rest of the needed items. I'm thinking about an air ride suspension. Not to drop it on the frame, but because I've heard they are the best ride. Any input would be appreciated.
Once I have the wheels picked out, I hope to sell the rims on the truck. They are the style on the General Lee. I'm sure there is a General Lee guy out there that would like to buy them.
YEEEE HAAAA...
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-06-2007, 12:09 AM   #31
Green Machine
Re: New guy here
You may be able to change the outside gear to adjust for rear ratio change, that is easy, but you may not be able to get enough tooth change, changing the inside gear is a pain,tranny has to be disasembled. Here a link for the ratio boxes : http://www.transmissioncenter.net/sp...n_______va.htm
I am assuming you have a 3 speed manual, if 3 speed auto like turbo 350, it is easy to change outer and inner gears to get the speedo right.
Old 01-06-2007, 08:33 AM   #32
cgoodwin
cgoodwin's Avatar
Re: New guy here
its a turbo 350.
Old 01-06-2007, 08:34 AM   #33
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: New guy here
Nice Rig
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-06-2007, 08:44 AM   #34
nutsforchevys
nutsforchevys's Avatar
Re: New guy here
thanks for all the welcomes guys! I appreciate it.
Anyone have tricks to keep the gas smell down in the cab? I'll do the bed tank sometime, but not right now. It's even worse now that I've changed out the sending unit.
My truck had that smell when I bought it. I removed the tank and sure enough there was a small pin hole in the tank. I had it repaired and it doesnt smell at all anymore. Welcome to the board!
72 Super Cheyenne lwb 4X4 Ocra / White
88 Chevy 1 ton Dumptruck
88 Chevy 1ton Flat bed 4X4 white
nutsforchevys is offline   Reply With Quote
Old 01-06-2007, 01:27 PM   #35
cgoodwin
cgoodwin's Avatar
Re: New guy here
I think the smell is coming from the fabbed up adaptor we made to get the new sending unit to hook up to the feed line.
I bought a new sending unit for a v8 not thinking the truck originally had a straight 6. The v8 sending unit had a bigger connection. We used the old sending unit connection and the size for the new sending unit with a piece of fuel tubing. Soddered them together and hooked it up. I'm going to tighten it down some more, but it that doesn't take care of it, I have a plan.
First, petition the wife for more funds this month for the truck. Then buy the rear tank kit.
If that fails, then use rubber fuel line with some clamps because I'll be doing the rear tank conversion at some point.
