Old 01-13-2007, 12:33 PM   #26
shifty
Questionable
shifty's Avatar
Re: LQ4 Engine Wire Harness
Dean makes a good point - if you have a choice, dodge the 4l60e. i keep hearing horror stories about people eating them up in trucks.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-13-2007, 12:58 PM   #27
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
I am lucky there. The donor motor 6.0l is already mated to a 4L80E.
Anyone out there have any experience with Current Performance for engine wiring harnesses?
http://www.currentperformance.com/
Sandemonium is offline   Reply With Quote
Old 01-13-2007, 01:44 PM   #28
shifty
Questionable
shifty's Avatar
Not I. Again - highly recommend feeling around over at the Conversions and Hybrids forum at Ls1tech. My member name over there is: shifty`
Only takes a second to post - and it could help save you hundreds of bucks.
Old 01-13-2007, 02:07 PM   #29
Sandemonium
Thanks for the reply Shifty.
I have been looking at the posts at LS1Tech and spent several hours reading your posts of your build.
I'll post my question over there also.
Thanks again for your help.
Bob
Old 01-20-2007, 09:44 PM   #30
onetonk5
Cereal Killer
onetonk5's Avatar
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
anyone use this for a in tank efi conversion?
onetonk5 is offline   Reply With Quote
Old 01-21-2007, 10:47 PM   #31
shifty
Questionable
shifty's Avatar
That in-tank pump is the same one installed in the tank that FCG made for me.
Old 01-22-2007, 02:29 AM   #32
68GenIII
Originally Posted by 68 short step View Post
heads, bigger bore, and stroke sorry i cant be more specific...
The stroke is the same, actually all the gen iii motors (5.3, LS1, LS6, LS2, 6.0) share the same stroke except the 4.8. and the LS7.
68 lwb to swb Cummins swap in the works. I promise it will be cool someday.
68GenIII is offline   Reply With Quote
Old 01-22-2007, 05:35 PM   #33
shifty
Questionable
shifty's Avatar
I love that we have so many guys here that have delved into the late-model drivetrains
Can't wait till mine is up and running.
Old 01-23-2007, 10:35 AM   #34
Sandemonium
The aluminum underbed tank I am using only has 1 large hole in the top for either a sending unit or fuel pump.
Since I would like to know how much gas is in the tank I will be using an inline pump, something like a Walbro 255.
Not what I would like to do, but given the choices I don't see any other options.
Bob
Old 01-23-2007, 10:51 AM   #35
bodydropped68
bodydropped68's Avatar
bob i guess your pretty far into your project now, but have you looked at street & performance for info and parts? http://www.hotrodlane.cc i've been using them on my conversion. later paul
bodydropped68 is offline   Reply With Quote
Old 01-23-2007, 12:56 PM   #36
shifty
Questionable
shifty's Avatar
S&P is great for parts, I've used them several times but they do mark up their products a LOT. Expensive stuff.
Old 01-23-2007, 01:59 PM   #37
Sandemonium
I have seen the S&P catalog and found some nice products, but the price is a little high and I don't mind shopping a little to get what I am looking for at the best price I can find.
Thank you for the suggestion.
