11-22-2014, 12:54 AM | #26 |
60-66 Nut
Re: Power Steering Conversion for 60-62-answers
I don't quite understand how the pitman arm is causing a problem with the power steering pump. The pitman arm should be connected to the steering box and that should be positioned the opposite direction from the front cab mount. What steering box adapter plate are you using? The power steering conversion should work with a factory or original style replacement steering box and pitman arm.
11-23-2014, 08:06 AM | #27 |
For you guys that did this conversion, How close does your Centerlink get to the Crossmember? Mine gets really close. like within probably 1/8 to 1/4 of an inch.
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
09-25-2015, 09:49 PM | #28 |
But Found Her 25yrs Later!
I'm trying to track down exactly what collapsible shaft to use for the 60-62 trucks.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-25-2015, 11:41 PM | #29 |
this is what I did with mine ( I know it is not collapsible) but it should give you an idea .
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 09-25-2015 at 11:52 PM. |
09-26-2015, 12:23 AM | #30 |
60-66 Nut
Since your cab is a '65, is your steering column a '60-'62 or a '63-'66?
I have not done this, but I would think that a '73-'87 collapsible steering shaft would work.
09-26-2015, 11:25 AM | #31 |
It's presently a 60-62, but I have a 66 th400/th350 column I will be swapping in when I install my th350 tranny.
09-26-2015, 01:19 PM | #32 |
Not sure if this helps, some more info.
Just put an colapable Borgeson set-up in 1964 K10, for safety and really tight steering. Used two universal joints and a shaft. Not cheap but works really well. Used original shaft and cut some of it off, plus a little machine work on end connecting to one of the universal joints. This set up gets rid of the rag joint ( much tighter steering). The set-up allowes the steering shaft to be centered in firewall and cab, as the PS conversion moves the connect at the steering box out from the frame some, changing the original alignment of shaft. Will post more info on parts/ process soon, here are a couple of photos. Les Last edited by aotte1; 09-26-2015 at 01:37 PM. |
09-26-2015, 01:21 PM | #33 |
Another photo
09-29-2015, 11:33 PM | #34 |
03-25-2019, 04:49 PM | #35 |
Got any better picture of the bracket on the frame before installing the box? And better pictures of the box bolted up? It looks like the top rear bolt bolts the box to the bracket.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
