#26 |
Re: Impala SS/Caprice rear disc brake BRACKETS
me needs some for a 10 bolt
#27 |
sent you a pm
#28 |
Next project: 1970 K10
Just so everyone knows, since a TON of people have been asking, I will be working on coming up with a bracket for the 93-9? Camaro calipers that have an e-brake. No promise as to when they will be ready, but my guess is about a month.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#29 |
10 bolt anytime soon?
#30 |
here is a pic of them mounted.
#31 |
Thanks for the pics, Ram-Man! My supplier informed me today that they are out of stock, and won't have the adapters for 5-7 days. I'll let you know when they come in.
pcmcobra - When things slow down, I will see what I can do. It may have to be a one-off set, but I will see what I can come up with after things get settled down here.
#32 |
sweet,
thx a bunch. Will give me a little time to recoup from dropping some $ on my wheels and drop kit. John |
#33 |
As glock said, I have confirmed that the Impala brakes will fit behind a Rally wheel. Glock's brackets are a steal considering trying to make these things yourself.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
#34 | |||
Union Electrician
About how much total for the swap, including the parts needed? I would like to have an idea before I jump on board. Are you able to retain an ebrake with this style? about the oem brakets needed, can you buy them or is it bone yard only?
Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#35 |
Never Done?
![]() Join Date: May 2000
Well it depends on if you're going to use all brand-new parts or not. I'm looking at ~$450 using rebuilt calipers, new caliper brackets (they are available), slotted & cross-drilled rotors, the CPP prop valve, new hoses, banjo bolts, etc.
I've not seen anything about an e-brake with this set-up. |
#36 | |
If you really want an e-brake, I have a set of Camaro calipers soming to use for designing a bracket for them too. They do have on integral e-brake.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 01-11-2007 at 12:06 AM. |
#37 | |||
Union Electrician
OK, I will wait on the camaro style.
Thanks, Randy
#38 |
Randy, I'm hoping I can have something within a month.
#39 |
#40 |
Sweet!! They look great! You may need to sand a little powder coating off on the inside of the large hole, as the first batch were fitting kind snug to the axle flange. Just an FYI.
#41 |
Bob put me on the list for the Camaro brackets.
Ken svr1113@cox.net
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
#42 |
Your on, Ken!
#43 |
Thanks for the heads up. Maybe I will get around to putting them on in the next couple of months.
#44 |
LOL, lets hope it's sooner than that!
#45 |
any chance of designing a bracket for a 10 bolt rear end.
#46 |
Like I said earlier in this thread, when things slow down a little, I will look into making a couple sets.
#47 |
count me in if you have 10 bolt plates made preferrably with the camaro caliper...thanks, taylor
#48 |
Gotcha!
#49 |
![]() Join Date: May 2004
Only the distribution valve needs replacing & not the master cylinder?? I thought you would need a disc/disc m/c instead of a drum/drum....
#50 |
I was under the impression you could run the same m/c (and some board members have). Drum/drum brakes require an equal volume of fluid since the wheel cylinders are almost equal, and the disc/disc would be very similar too.
See post's #12 and #13: http://67-72chevytrucks.com/vboard/s...ghlight=impala
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 01-12-2007 at 08:41 PM. |
