Old 01-13-2007, 10:31 PM   #26
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Stage 1 Complete
Originally Posted by low'n slow View Post
Used a York compressor. Is ths an option, or are there not enough pulleys?
I have the York, but I would have to loose something, if it was smaller then
I could consider mounting it low like a smog pump under the A/C compressor
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-14-2007, 08:02 AM   #27
Rokcrln
Rokcrln's Avatar
On my last rubicon built Early Bronco I used the a/c comp off a 5.0 mustang for my on board air. It is alot smaller than the yorks that I have also used and put out as much air as well. They are about6" around and 10" long give or take. What you can also do is replace your york with a sansen (sp?) comp for your a/c and also use the 5.0 style for air and you will save alot of room. This was the only shot I had on my hard drive. But it gives you the ides.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-14-2007, 10:23 AM   #28
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Thanks Kevin, I may keep that in mind
Old 01-14-2007, 10:54 AM   #29
Hart_Rod
Hart_Rod's Avatar
Merlot's looking good! Did you ever find another 67 grille? If you put the compressor at the rear and mount it with good rubber bushings it's not as loud as you would think. Plus, with you running 2 tanks (6-10 gallons of air??) the compressor would only come on every other time you aired up.
Hart_Rod is offline   Reply With Quote
Old 01-14-2007, 10:59 AM   #30
meathead95
computer illiterate
meathead95's Avatar
what does merlot stand for? or where did you come up with it?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 01-14-2007, 11:06 AM   #31
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Actually only running a max of 5 gallons storage air, front tank is 2 gallon
and the rear is a 3 gallon, I won't change that because I like the stealth
look of nothing in the bed, most I've looked at say "out of the elements"
so It looks as if I am going to have to install it somewhere, idea pending.
Keith, then name of the Blammy was "BLOCLVL" but I deceided that she
would never be that low since I want this thing to be movable if I have
a major issue while traveling, right now I can drive it aired out (Barely)
so I changed it to "Merlot" if you look at the pic's the flash makes it as
if she's redish, she's really more of a maroonish, so "Merlot" like Wine
Old 01-14-2007, 01:38 PM   #32
Ron 586
RIP Mr Ron
Ron 586's Avatar
Which side is your A/C compressor on in Merlot.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 01-14-2007, 01:42 PM   #33
[ol'Blue]
[ol'Blue]'s Avatar
Side Shot!!!
[ol'Blue] is offline   Reply With Quote
Old 01-14-2007, 03:21 PM   #34
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
SWP set-up, so it's on the passenger side
Old 01-14-2007, 04:20 PM   #35
Ron 586
RIP Mr Ron
Ron 586's Avatar
I'll have to do a little digging but I should have all the mounts and a compressor for the driver side. In the 70's the A/C was on the left side with the old style long compressors. Let me know if you want me to go on a treasure hunt.
Ron (Mr Round Tuit)
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Old 01-14-2007, 05:03 PM   #36
71swb4x4
71swb4x4's Avatar
Looks real good Craig!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-01-2007, 10:27 AM   #37
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
All cleaned up
Old 04-01-2007, 11:10 AM   #38
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Looks good Craig. I like the roof rack!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-01-2007, 03:42 PM   #39
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
TYVM, I am dead set on keeping it, however it's topless time
Old 04-01-2007, 04:22 PM   #40
jkade
jkade's Avatar
Originally Posted by LUV2XCLR8 View Post
All cleaned up
Is that aired out?
jkade is offline   Reply With Quote
Old 04-01-2007, 07:25 PM   #41
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Yeppers, 15" wheels, factory snubbers, tall cups in the front, and No c-notch, yet
Old 04-01-2007, 07:38 PM   #42
71swb4x4
71swb4x4's Avatar
And 2.5" drop spindles
Old 04-02-2007, 07:35 AM   #43
vtblazer
vtblazer's Avatar
Smart decsion right there.
Really nice, clean lookin' 2wd drive Craig.
vtblazer is offline   Reply With Quote
Old 04-02-2007, 02:40 PM   #44
jkade
jkade's Avatar
Ok, I was just wondering since I am that low with my static drop.
Looking good.
Old 04-02-2007, 02:49 PM   #45
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Oops, forgot that part
Old 04-02-2007, 03:10 PM   #46
Yukon Jack
Post Whore
Yukon Jack's Avatar
You know I like it!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
