Old 03-06-2007, 07:20 AM   #26
49studebaker
49studebaker's Avatar
Re: 67 hood on 71?
Ok, to fill the gap. That explains why the top bar (grille molding as they call it) is so bulky looking. It was added to take up space.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 03-06-2007, 07:47 AM   #27
1LoC10
Insert Title Here
1LoC10's Avatar
Re: 67 hood on 71?
wouldnt it be a lot less work to make the 69-72 grill fit on a 67-68 front clip.. im not body man, but I think I would want to make a grill opening bigger before I chopped two hoods, or layed one back
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 03-06-2007, 08:19 AM   #28
Rokcrln
Rokcrln's Avatar
Re: 67 hood on 71?
Originally Posted by N2GMTrux View Post
There was an issue of Classic Trucks where they showed the entire process of removing the front brace on a 69-72 Chevy hood. Then they pie cut two inches around the front of the hood. Then they tampered the cut on the sides of the hood. Meaning pie cut all they way back,,, almost to about four inches from the back of the hood. What they did is made a 69-72 hood look like a 67-68 hood.
Yes I saw that mag and trust me they left out alot of what needed to be done. They did not even show what had to be done to remove the front brace or and of the time consuming parts. If you are not a body guy I would not read their artical and think you know 1/2 of what was needed. That is one the the write ups that pissed me off because they have a very large reader base that takes what they say as truth and learns from ther stuff. So when alot was left out or skipped it was like giving the mid term before giving hte homework!
Sorry for the rant. One day I will show how to do both with full write ups or maybe just a DVD how-to instead. But it will not be for awhile with my curent schedule.
Keep in mind that the 67-68 front latch will still need to be used unless you section the 69-72 inner front hood brace as well. Their is a height differance between the two if I remember right.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-06-2007, 11:03 AM   #29
1lowdiesel
1lowdiesel's Avatar
Re: 67 hood on 71?
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 03-06-2007, 11:42 AM   #30
raggedjim
raggedjim's Avatar
Re: 67 hood on 71?
There is a top bar on a 67 and a 68. It doesn't look anything like the 69-72 topbar but it is there to fill the gap between the hood and the grill and also to give a method of attaching the top of the grill to the fenders.
The white GMC has the top bar painted black, the other pic shows the topbar removed from the grill.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
