01-15-2007, 08:39 PM | #26 |
Re: what kind of welder you own
Hobart handler 180 (220v) with gas.
01-15-2007, 08:53 PM | #27 |
love my clarke 135en.
01-15-2007, 09:17 PM | #28 |
We have 6 miller, part # "big huge" migs & a miller tig at work. I usually do my welding there.
There is also a miller plasma cutter, 3 press brakes, 5 laser tables, 2 CNC mills, 1 CNC lathe, a CNC saw & lots of other things that I dont know how to run. I run the lathe & mills there... |
01-15-2007, 09:21 PM | #29 |
I bought a lincoln sp170t back in 1995. It still works great. Need to get it off of the fluxcore, but it is easy to use this way too. I have the regulator, just need a bottle.
Jason |
01-15-2007, 10:25 PM | #30 |
Active Member
01-15-2007, 11:51 PM | #31 |
lincoln sp-135 plus flux or gas
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
01-16-2007, 12:24 AM | #32 |
Hobart Handler 140 MIG with gas. Works great for all the jobs I do, and before I bought it I'd never welded a day in my life.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
01-16-2007, 12:51 AM | #33 |
ive got a weld pac 100, with a gas kit on it. works great up to 3/16,1/4 is pushing it. works great on everything else, i realy need the 175 because i am starting to do a lot more 4 links and I just dont get enough penitration when trying to weld the axle brackets on.I must say though the gas kit made it a new beast, the flux core made for some poris welds, make a small tack wth flux core and you bend it once to brake it off, make the same size tack with the gas and you have to work at it to brake that tack!
01-16-2007, 01:39 AM | #34 |
Wrenchin & Sandin!!!
Right now I'm trying to decide between the Lincoln Weld Pak 100HD and the Weld Pak 3200HD
Randy Shorewood, IL. My Favorite eBay Searches My Driver Restore Thread 1971 C10 Longbed 2005 Silverado Shortbed 2005 FXDWG |
01-16-2007, 01:44 AM | #35 |
JD "Epoxy" weld.
That will change next month with a new mig |
01-16-2007, 03:30 AM | #36 |
Lincoln Pipeliner 200G. Well, it really belongs to the company I work for. It actually has a 4 cylinder Chevy gas engine in it!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
01-16-2007, 07:10 AM | #37 |
I have a lincoln AC225 stick welder for the heavy stuff and a Lincoln 175 plus for sheet metal and all the small stuff.
01-16-2007, 09:50 AM | #38 |
lincoln 225 amp ac/dc stick and a 120v lincoln weldpak 100...
01-16-2007, 12:51 PM | #39 |
English Chevy Owner
Sip Migmate 150 Turbo and a cosmo el cheapo stick welder.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
01-16-2007, 01:22 PM | #40 |
i have a miller 175 that i won as a door prize at turkey rod run a few years back prior to that i had a lincoln 135 for many years liked both but am unable to weld now due to poor eyesight problems
01-16-2007, 02:08 PM | #41 |
Questionable
Lincoln 175
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
01-16-2007, 03:05 PM | #42 |
I have a Decca 105E gas mig. I haven't used it much but it seems to work great and the price was right.
1946 Chevy ton truck 1972 Chev C30 1975 Scottsdale C10 |
01-16-2007, 10:11 PM | #43 |
Lincoln 225 ac/dc arc , an old reliable Miller Matic 35 mig and the new toy a Miller Matic 251 with an aluminum spool gun, soon to purchase for doing stainless. Never tried a wire fed stainless.
01-16-2007, 11:26 PM | #44 |
Next project: 1970 K10
Left to right:
Hobart 135 Miller EconoTIG/stick Thermal Dynamics EconoPak 50 plasma cutter Miller 210 MIG Soon to be added to the lineup - PlasmaCAM CNC plasma table with a Thermal Dynamics Cutmaster 101!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
01-16-2007, 11:56 PM | #45 |
wheels67 says to Glock. " Hey Glock, look, Is that a bat in the sky up there?"
Meanwhile as Glock runs out of the garage, wheels67 loads his welding gear. lol |
01-17-2007, 12:03 AM | #46 |
And when Glock comes back into the shop, he still has his Glock Compact .45 in-hand, ready to dispatch said bat. Meanwhile, he notices his welders missing.....
01-17-2007, 12:13 AM | #47 |
My weldpac 100 is making me feel inadiquate....I want a bigger welder
01-17-2007, 02:15 AM | #48 |
someday it will be done!
MM210 & M 180SD tig in my shop.MM 251 & spectrum 375 plasma (I'm envious) in my pa's.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
01-17-2007, 02:35 AM | #49 |
Miller Challenger 172 here.
Man I want a plasma cutter....
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
01-17-2007, 04:10 AM | #50 |
English Chevy Owner
I need to make a cart for mine, I feel like a poor cousin carrying it around!
