Old 01-25-2007, 08:47 PM   #26
chevyc1068
chevyc1068's Avatar
Re: How do you make 350+hp in a 350??
So if i went with the vortec heads what else would i need for a completed head/valvetrain. And what would it do to compression? Would I have to go to dished pistons or could I keep the flattops and still run it off 89 octane fuel?
1968 C-10 longbed, 307 V8, 4spd- currently under construction
chevyc1068 is offline   Reply With Quote
Old 01-25-2007, 09:00 PM   #27
Billla
Billla's Avatar
Vortecs require self-aligning rocker arms - the CompCams self-aligning roller tips are a good choice. If you are not using more than .475 lift then the stock Vortec springs are fine. The GMPP Vortecs are 64cc - so depending on your existing heads there would be no change in compression.
Billla is offline   Reply With Quote
Old 01-26-2007, 10:44 PM   #28
chevyc1068
chevyc1068's Avatar
Thanks for the input guys.
