#26 |
![]() Join Date: Apr 2013
Re: quick ratio steering box ( which to buy )
My dealing with a so called quicker steering box is that 72 and earlier were 4.5 turns lock to lock. And I know from mid 70 up they were all 3.5 turns lock to lock. It is a definite improvement from original. Plus it isn't so sensitive that I still can be a carefree going down the road and yet it still responds very nicely.
As far a new or reman, It depends on your comfort level with you parts supplier. |
#27 |
I just replaced my leaky box with an Orielly's Cardone one. So far so good. My steering improved greatly. Hope it doesn't wear out too soon. It was a pain in the ass. I had to grind one of the casting bosses down so it would fit in my 67. Going to install my 19 dollar stock sway bar(Junkyard) this week and see how it changes my handling.
My boss suggested I buy an extreme ratio one from Summit. It's not a show or race truck so I went with the less expensive option atm.
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
#28 |
Thanks. I tried to get one at cpp that has a lifetiime warranty with it, they do not have them for 4x4.
What is the warranty on yours? I am replacing a Napa rebuilt that is less than 2 yrs old! So I am looking for something that should be reliable. |
#29 |
Red Head Steering Gears. Not cheap but will probably be the last box you have to buy. I think Wes carries them and they are a better ratio than stock.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#30 |
Is the steering gear from an 87 considered a quick steer ratio.
#31 | |
Posted via Mobile Device |
#32 |
My set up using a cpp box, your 67 will not need to be dimpled with this box.
http://67-72chevytrucks.com/vboard/s...d.php?t=729738 |
#33 | |
#34 |
The part numbers that i used are in the post that i sent you, hope it helps I bought them through summit
RJC-730R is the Ragjoint CP UHK universal hose kit both from CPP or summit racing |
#35 | |
#36 |
Any incidental parts you may need I got from JJ inline parts. ( I believe he is in Oregon also )
http://www.jjinlines.com/ You can email him but if you PM me i can give you James' cel number |
#37 |
I used an AGR steering box on my C10. They're a little pricey but I've been happy with the performance.
#38 |
![]() Join Date: Nov 2007
I'll just reiterate this right here. Just put one in mine and its MUCH better than stock.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
#39 |
I installed a rebuilt Cardone part number 27-7512 that I ordered from Amazon. It's for a 1977 half ton C-10. Works great with no play and no more leaks.
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
#40 |
While looking for this same info for myself I noticed a few people referring to the GM800 box used on passenger cars. Way different than truck boxes. They mount on the inside of a wide frame, trucks on the outside of a narrow frame. They are great boxes but basically built 180 degrees in architecture. Won't wok.
