Old 01-28-2007, 01:03 AM   #26
CHAPS7931
CHAPS7931's Avatar
Re: How can I remove this rust?
remember its a combination of chemical balances and if yuo add to much acid it will irritate your skin
CHAPS7931 is offline   Reply With Quote
Old 01-28-2007, 02:54 AM   #27
Aarons72s
True. When she added it it was only 1 gallon in a 20' x 4' above ground pool and everyone stayed out for a week to let most of teh acid neutralize.
Aarons72s is offline   Reply With Quote
Old 01-28-2007, 02:17 PM   #28
wolfthing2000
Rust Mort and Metal prep are almost identical and convert the rusted metal real well. Then use the encapsulator, like Rust Bullet (very good) POR 15, or Rust shield. This stuff can then be topped with an epoxy sealer and painted over. The encapsulators block the oxygen required for corrosion and as long as nothing gets scratched compromising the surface, the process works real well.
wolfthing2000 is offline   Reply With Quote
Old 01-28-2007, 02:48 PM   #29
ChevyDude
I had all parts like that "fine sand", blasted.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 01-28-2007, 02:50 PM   #30
BigSky71
LAIDOUT
BigSky71's Avatar
I haven't used muriatic, but I used a phosphoric acid I bought at Lowe's. KleanBrite brand I think it is, in the paint section, a gallon for 12 bucks or so. I bought an empty spray bottle and sprayed on it my rad support and bottom of the cab prior to POR15. I applied it several times, scrubbed it with little wire brush, then washed it off. It took a few applications for the harder stuff, but on new surface rust the phosphoric eats it in just minutes.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 01-28-2007, 02:52 PM   #31
larry may
http://www.stovebolt.com/techtips/ru..._derusting.htm
This is an older thread talking about removing rust. FYI.Larry
ttt
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
