#26 |
![]() Join Date: May 2006
Re: Post up a picture of your plug wires!
I wish there were a way to run the wires under the headers on a big block, Really looks crappy.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
#27 |
PITbut
#28 |
wow,,,old thread!!!!!!!
Anyhow I will post picts of mine..MSD 8mm..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#29 |
Sweet Job BigAl71
Heres Logans engine, The looms are made to mount on traditional valvecover bolts, but we were using centerbolt heads....So we just bent the bracket and bolted the loom to the head instead, there are holes already in the head, 1/4" I think they are so you can mount the early style spaqrk plug heat sheilds. chas
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
#30 | |
blood type; Retumbo
as for the opening poster I can show what i did have. |
#31 |
sharp as a marble
![]() Join Date: Jan 2007
mine are like ETsC10. Alot of mid to late Vettes were run this way. Nice and clean. The front two on each side are under the motor mounts
#32 |
![]() Join Date: Jun 2006
Here's how I did mine. Pretty close to headers, but so far so go.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
#33 | |
Thank you!!!!
#34 | |
Sierra Grande Club
Thanks, s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#35 |
If I recall correctly, I got those from Jegs. I think they were a universal "under header" set.
#36 |
Sierra Grande Club
Since I started this thread I still don't have a picture of my Kingsborne wires on. But here are some of Napa Wires for a mid 70's Corvette. I didn't like how they fit so I routed them how I wanted and measured for my own.
I also have my heat shields installed. s/t ![]() ![]() ![]() ![]()
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 11-29-2008 at 11:51 PM. Reason: Pictures a bit on the large side.... |
#37 | |
Sierra Grande Club
