#26 |
Re: impala rear disc???
So to sum things up, do certain rearends and/or axles need a specific bracket thickness? I'm kind of confused from this thread. If so, Glock, can you post what situations need what bracket thickness?
#27 |
My Rearend is a 71. You need to radius the outside corners the same as the inside of the rotor. Plus you need to get the outside lip of the parking brake drum cut off on a brake lathe so that the rotor does not hit the backing plate on trucks that have a lot of axle walk. My caliper bracket bolt holes are 1/2 sae thread and you need to drill out the caliper bracket bolt holes a little for the 1/2" bolts to go through.
#28 | |
Next project: 1970 K10
Let me know if you have any issues when the time comes, and I will get you a new set. Bob
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#29 |
![]() Join Date: Oct 2006
Couldn't you just mill the mounting area 3/16 and leave the bracket 3/8 thick? also for the mounting bolts couldn't you use button head allen bolts? Just a thought.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
#30 |
I would also be interested in a set of these brackets. How much are they?
#31 |
Lance - They sell for $50 a set with hardware, which will include new/different bolts for the OEM bracket to fix that clearance issue. I still have some 3/8" brackets, and will have 3/16" brackets soon.
I might have to try that on a set, to mill the area that mounts to the flange down to 3/16".
#32 |
I put mine on last night and the same thing happened with mine. I am going to try and go to the parts store today and see if I can come up with a bolt that will work. I am not mad at you Glock these kinda things happen and if they are going to happen it will always be to me. I will let you know what I come up with.
Thanks |
#33 |
Thank you for understanding Kade. And like I said earlier, I will replace ANY and ALL of those that will not work with the new, thinner brackets. I do have the thinner ones in the process of being made as we speak, and hope to have them ready to go by the end of the week.
#34 |
I think I will try something like these. What yall think? |
#35 |
For me, I need to buy new axels to go from 6 to 5 lug, so If I buy the 72 5-lugs, it sounds like the brackets'll work? I like the thick flange bracket, but since the stock flange is thinner metal, Glock I may need two sets of thin for the two thicks I got? LMK, no hard feeling, glad I saw this before I went out and had to throw stuff!!
#36 |
You might still be able to use the 3/8" brackets if you are using the earlier (shorts) rear end housing with later 72 (longer) axles. But if you still have a clearance issue with the thicker 3/8" brackets, i will send you a set of the 3/16" brackets no problem.
#37 |
I hope I didn't open up a can of worms on this thread
#38 |
Keep in mind, and you should be able to confirm this once you have the thinner brackets, but you should gain another 3/16" clearance from the bolt head to that lip with the thinner brackets. Since they are 3/16" thinner, the head should set in another 3/16" away from the rotor.
I think ![]()
#39 |
hey glock, what's the status on the camaro brackets? Did you get those calipers yet?
#40 |
My rearend is the wider one with long axles. Here are some pictures.
