#26 |
Self-proclaimed LED man
Re: What did y'all get done this weekend?
Made some LED reverse lights and modified some 6' oval amber trailer lights to fit into the parking lights in the front bumper. I think i might make a build thread here in a little while
Justin
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
#27 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Welded up all the holes in the front frame section. Broke out the primer gun and primed the front frame section por-15 will be next.. Started filling in the firewall holes and monday I will order my strong arms and bags... Went to a car show saturday..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#28 |
Currently Blazerless
Took a little road trip today to pick up the new extended cab project, drove it back 250 miles without any problems.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#29 |
Tightwad
Didn't work on the truck over the weekend had worked on it during the week but , went and got me some new sanding blocks and sand paper and a palm sander. This 70 weather had to barbeque on the grill today and drink some cold beer and back to working on the truck this wee before going back to work.....
Eric
56 Chevy custom cab step side under construction 55 Chevy 210 68 SWB Stepside back burner under construction 72 Chevy LWB 84 CJ 7 05 Chevy 1500 Crew Cab 30X40 DOGHOUSE(shop) with many add ons |
#30 |
Well, I went to Advance Auto Parts and bought a fitting and some 5/8" and 3/4" hoses to get my heat working.. Heat works great now..
I also greased the front of my truck's suspension.. Aligned my bed with the help of a friend.. my brake pedal is hard so I checked my brake fluid and there was no fluid in the rear and barely any fluid in the front.. I can bleed the front brakes but the rear brakes do not get any fluid to them??? I will have to figure that one out.. I assume either a bad master cylinder or prop. valve... Screwed down my shifter boot to the floor of my truck.. Put some water in the radiator.. I was going to change the float in my gas tank and install new tail light lens but my order from GMC Paul's has not shown up yet.. I'm hoping it will arrive today.. James.. |
#31 |
Ripped out old carpet, and painted the house inside preping for new carpet.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) |
#32 |
Active Member
Finished up door stuff. Vent windows back in, glass, seals, etc... Thanks FAQ list, it wasn't as bad as I was expecting.
#33 |
Never Done?
![]() Join Date: May 2000
Finished drilling holes for the rear air bags, and test-fit the trailing arm crossmember before I get to painting the frame.
I'm now down to 100 days to go from bare frame to running truck. This could get interesting. |
#34 | |
Licensed to Thrill!
My work times this weekend were: Started at about 10:00pm on Friday and worked until about 3:00am Sat. morning. Then Saturday 8:00am to 9:00pm. I accomplished the following: Removal of - TH350 tranny, flywheel, oil pan gasket, 2-piece drive shaft, cross member, pitman arm, and lots of grease, grime, and dirt. Installation of - 700R4 tranny, flywheel, oil pan gasket, 1-piece drive shaft (it's actually being shortened today to go back in tonight, but that's a snap), cross member, and pitman arm. It was a lot of work in 18 hours time. DLB |
#35 |
I love that color Orange. What paint did you use or do you have the paint codes to match it?
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
#36 |
got the impala running
![]() ![]() got my door and fender on my c-10 and even got some bling for the motor and got it running again. she purrs like a kitten too. ![]() ![]() http://s64.photobucket.com/albums/h1...t=DSCF1757.flv even had some time to make a hitch for my fullsize.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
