Old 03-08-2007, 10:18 AM   #26
Joe67
67 is sold
Re: Home-Made Speaker Kick Panels
Awesome - I need a set
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 03-08-2007, 10:36 AM   #27
cstanley
cstanley's Avatar
what a nice detail to go the extra mile and re-mount the fresh air controls! that is the pro way to do it.
hey frizzle, are you a primus fan?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 03-08-2007, 11:15 AM   #28
jkaylor68gmc
jkaylor68gmc's Avatar
I would be willing to purchase a set of those from you!
jkaylor68gmc is offline   Reply With Quote
Old 03-08-2007, 02:01 PM   #29
jd4300fel
jd4300fel's Avatar
Mike ,
Real nice job, You have me thinking of doing the same. Not to rob the thread but, I had a vision when you mentioned the tweeters on the dash has any one used the factory AC vents to mount tweeters in not just the hole's but the just remove the deflector?
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
Old 03-08-2007, 02:49 PM   #30
BigSky71
LAIDOUT
BigSky71's Avatar
I have intended to attempt this mod on my truck. Very cool, thank you for the write up!
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 03-08-2007, 03:18 PM   #31
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Originally Posted by jd4300fel View Post
Mike ,
I plan to mount the tweeters behind the vents in my truck. I did this on my mustang. Good way to hide them if you're going for a stock appearance.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 03-08-2007, 03:22 PM   #32
project1971
project1971's Avatar
I am going to have to look at this thread at the house..... they have the pictures blocked here at work
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 03-08-2007, 04:00 PM   #33
Orange
Licensed to Thrill!
Orange's Avatar
Man - those are great!
Terrific job! This is one project that a fella just needs to have some fiberglass for.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 03-08-2007, 07:09 PM   #34
Frizzle Fry
Frizzle Fry's Avatar
Thanks for all the props I wrote this up because it's so easy to make something so much nicer than what's available in the catalogs. This was my FIRST fiberglass experience and it's not difficult at all. The vinyl took some patience and attention to detail, but the whole thing was pretty darn easy.
Originally Posted by 67ChevyRedneck View Post
Great idea! By using a newer column or actually modding just the lever?
I got the cheapo plastic kick panels and my switch is useless behind it.
The idea is still brewing, but I think I will go see what's available at the parts store for replacement Hi-beam switches on newer car/trucks that have the turn signal lever switch (GM if at all possible ) I'd like yo get a three position switch--1)mid positions is low-beams, 2)push lever fwd to toggle on hi-beams, 3) pull lever back for momentary hi-beams (flash headlights). Then I'll figure out how to make it work in my column. I'll post what I come up with.
Originally Posted by muddpile View Post
I've thought about doing this, but one question: How well do the floor vents work now with the handles spaced out from the original location on the tin kick? Are they just out 3/8" or so (wood+fibreglass+vinyl), or are they more than that? If I could make that work, that would be killer!
Yep 3/8" is about right. The vents work perfectly. The flap/doors hit the intended hard-stop as designed before the puller rod touches the kick panel.
Originally Posted by Ozona View Post
Now that you've done these, what would you do differently next time?
I would love to hear your thoughts...so I can learn from you.
That a good question. Let's see...
  • The backer board bowed up slightly at the edges when the fiberglass cured. You may be able to prevent this by clamping them down around the edges after applying the resin.
  • The grooves for the wires were made at almost the same place that the vent puller bracket screws ended up (very close), so I'd put the grooves off to one side or the other rather than the center.
  • Tossing the vinyl in the dryer for a while before covering does help make it more pliable.
  • I didn’t mention that I took the longer dowels out after all the fiberglassing was done. Just knock them loose with a hammer and take them out. I left the short ones in place.
I wouldn’t give up those vents! And where else would Frizzle Fry come from?
DLB
First fiberglass job for me. Home Depot has the cloth and resin in the paint section. I must have used more hardener than I was supposed to because I had to go back for more before the resin can was even half empty Home Depot does carry the hardener by itself.
Frizzle Fry is offline   Reply With Quote
Old 03-08-2007, 07:21 PM   #35
Gary
Gary's Avatar
While you're at it, tell us about those door panels
Gary is offline   Reply With Quote
Old 03-09-2007, 10:57 AM   #36
project1971
man i checked out this thread here at the house and the pictures came through.... absolutly amazing! those are great! I am definatly going to have to make some of those! I am off today and that give me some insperation to go to the shop and work on my truck and get something done. Thanks for the walk through looks amazing.
2008 Ford FX2 Screw
Old 03-09-2007, 11:08 AM   #37
67ChevyRedneck
67ChevyRedneck's Avatar
Great! Keep us (mostly me ) posted on that!!
By the way, I'm putting a new carpet in my truck next month, so you have about 3 weeks to figure it out
I don't actually use my high beams (with the fog lights on with my low beams, I have plenty of light at night.) I'll probably just let it sit on top of the carpet for now. Don't want to cut up $120 carpet yet....
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-09-2007, 11:48 AM   #38
70rs/ss
70rs/ss's Avatar
I like it, would a 67-8 ebrake assembly fit? I know it'd solve the interference, just not sure if you could put the 67-8 ebrake set up in a 69 and up? Just a thought, very cool!!
70rs/ss is offline   Reply With Quote
Old 03-09-2007, 05:00 PM   #39
Frizzle Fry
I thought about that too. I have the hand e-brake out of my 61 and I think they are the same through 67 or 68. You know anything can be done, it's just a matter of how much work is involved.
Here's the scoop on the panels.
Old 03-09-2007, 06:30 PM   #40
grayw0lf
Wow! Very Nice work!
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 02-27-2008, 10:34 AM   #41
bcbasketball11
Official Track Changer!! woot!
bcbasketball11's Avatar
Incredible explanation, i will DEFINATELY be making some. Thank yyou so much for enlightening us with this knowledge haha. Can't wait to get started!!
When something breaks, it needs to be fixed. If it breaks again. . .
BUY A CHEVY!!!!
bcbasketball11 is offline   Reply With Quote
Old 02-27-2008, 11:04 AM   #42
atxsteve1
atxsteve1's Avatar
Nice job..looks good.
atxsteve1 is offline   Reply With Quote
Old 02-27-2008, 12:59 PM   #43
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
great job!!!!!!!
fantastic pics to boot!
awesome!
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 02-27-2008, 06:52 PM   #44
Madmandav
Madmandav
Madmandav's Avatar
I must be crazy, that's what the voices in my head keep telling me.
Project FROSTBITE
http://www.67-72chevytrucks.com/vboa...d.php?t=280249
http://www.67-72chevytrucks.com/vboa...d.php?t=287407
'72 Chevy longbed
'70 Chevy longbed (million pieces)(FROSTBITE)
'79 Monte Carlo
'07 Chevy HHR
'00 Yamaha V-star
'05 Monte Carlo SS Supercharged
Madmandav is offline   Reply With Quote
Old 02-28-2008, 03:06 AM   #45
chrislehr
Engine n00b
chrislehr's Avatar
awesome.
chrislehr is offline   Reply With Quote
