#26 |
Re: dana 44 spicer hubs dials
Mine have been cleaned up and are working great. One of the plastic dials broke where the pin goe's through, one hole only, I drilled new holes clocked over about 6 degrees and it works just fine. Of course it dosen't have the little extra bit of plastic like the original hole area and the dial pointer is off just a tad, but hay it works for now. Metal would be great in the furure.
Special-K your right the machinest would need to take in accout the coating. A nice lathe and they could be fairly easy to make. Good idea.
68 4x4, 454, 4 speed, disk brakes both ends, Sold my 69 SS396 Elcamino when young & stupid ![]() |
#27 |
Mudmizer,I did the exact same repair before.I couldn`t find the right split-pin,so I used a drill bit.It worked out just fine.I`m more picky,now and that would bug me on a "classic",though.(I`m sittin`on n.o.s. hubs,now)
These metal dials are a great upgrade.I always got the Warn Premiums because I didn`t want plastic.I think the powdercoat could be omitted,though.I think it will lift at the edges and peel.Especially with aluminum.Oxidation will get under there and pop it off.This is my opinion ![]()
#28 |
72 chevy
![]() Join Date: Jan 2007
Ill have to get a picture its like a full time hub iv never seen this kind before. I think i found a set of lockouts though ill post some pictures.
Ed |
#29 |
Oh,ok.You don`t have the lock-out option.Which is rares than having the option.I`ve,personally only seen a few and they were all 1/2t.It`s just a slightly convex plug.You need the complete l/o assembly.I`d like to see a pic.
#30 |
Went to the 4X4 swapmeet in Puyallup, WA. this last weekend an found a fella that had two sets of the hubs, spacers and all, with a few extra parts and ALL GOOD DIALS, excelent shape. everything for $25.00.
Sooo... I'm good for a while.
#31 |
72 chevy
Heres a picture of the as you call it no lockout option and one of my lockouts i just found for the truck.
The 2 lugnuts are the no motor option LOL!! And its a mud truck no reason to get fancy lockouts. Ed |
#32 | |
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
