Old 03-10-2007, 08:17 PM   #26
msgross
msgross's Avatar
Re: Where is your spare
I figure that if I get a flat, then I will take it off the Tahoe (steel wheel) when the wife picks me up! doubt it will fit though (better check)
I don't plan on running one right now... i only bought 4 tires as well!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-10-2007, 10:10 PM   #27
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
I am surprised- actually quite surprised.
I drive my truck almost every day and would never consider not having a spare. Guess I will pick up one of the vertical bed mount carriers and bolt it to that inside the bed on the driver's side.
It has been several years since a flat on anything but the mower, mower trailer and the wheelbarrows, but I want one anyway.
I enjoyed the responses, especially the one about "around my seat belt". Knife makers call that an "organic tool rest", a very important tool for grinding blades
Thanks, everyone. You guys made me smile several times.
Just finished my third straight 16 hour day on the truck, finishing the windscreen channel for the installer and some other odds and ends, including a couple hundred feet of wire in the engine compartment. I forgot how much I enjoy the smell of flux-core solder.
Picked up my new cowl hood from the painters, hope to have the truck back on the road within a month or so. Will try to remember the camera tomorrow in case anyone has forgotten what primer, over-spray and sand paper look like
Thanks again,
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 03-11-2007, 03:41 AM   #28
dopeslap
dopeslap's Avatar
Originally Posted by 19673ontree View Post
why would you want move the tank from behind the seat ?
my spare will be in it's stock location under the bed where it go's (LOL)
Because that in-cab gas tank may cause you to die a very painful death.
Six months ago I bumped into a lawsuit involving a young man that crashed a 1970 long bed. In the impact, he suffered a dislocated hip from the lap belt. He would have been fine but the cab was quickly engulfed in flames from a slow leak in the gas tank behind his seat. Bystanders testified that even though the driver was concious he became disoriented and could not get out of the truck. The heat was too intense for them to pull him to safety so the guy just burned while they were yelling instruction to him on how to get out. After what they estimated to be ten minutes, the driver finally kicked out the windshield and crawled out on the hood. As they pulled him off the hood and put the fire out on his body, large chunks of his skin just fell off. He layed in the hospial for a few hours in miserable pain and then died.
Sorry to be so graphic (although the pictures are a hundred times worse) but you asked the question. Even a slight risk of burning alive makes this relatively easy mod well worth the time and $. Move the tank and find a new home for the spare.
dopeslap is offline   Reply With Quote
Old 03-11-2007, 09:55 AM   #29
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
and I hope the judge throws it out.
Here's the key part.... you said... a LEAKING gas tank...
It takes one hell of an impact to do anything to a stock in cab tank... if it doesn't leak anyways. And if it leaks, you're a friggen retarded tool for driving it.
Old 03-11-2007, 11:45 AM   #30
RANDY COX
RANDY COX's Avatar
That's why I like the burb the spare is in the back and the gas tank inside of frame.When I git my 33's it's gonna be a tank.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 03-11-2007, 12:19 PM   #31
Spare?I have plenty laying around the house and my shop.I have onr under my bed,but it`s prolly been there since the truck was new.Seriously,I pulled the spare,this year,from my CheyenneSuper and it was a factory 8.25x16.5 rim and a bias 8-ply...original.
The tank behind the seat is a safe place.We`d have heard about it by now after 30+ years.
Old 03-11-2007, 01:47 PM   #32
brak
brak's Avatar
what's a spare???
seriously, none of my trucks have ever been able to accomodate a spare in the stock location, typically due to to exhaust.
I usually keep a tire in the bed, which can be removed if need be
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 03-11-2007, 03:47 PM   #33
dopeslap
dopeslap's Avatar
I share a similar attitude regarding the merits of the lawsuit. But that doesn't change the fact that but for the location of the tank this fellow would have survived the accident with minor injuries. The risk may be low but the potential outcome is devastating enough that moving the tank becomes a no-brainer IMO.
Old 03-11-2007, 04:06 PM   #34
Elsie72
Chinook Arch
Elsie72's Avatar
I throw my spare in the bed, and it has been there for 5 years. I really should buy a lug wrench one of these trips to Canadian Tire, tho.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus.
Elsie's truck
2.5" dual exhaust with Hooker Aero Chambers
Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350
ECE drop 3.5/5
Elsie72 is offline   Reply With Quote
Old 03-11-2007, 04:46 PM   #35
Longhorn Man
when you get sued for havin a fuel tank under the bed that sprays and ignites all over some one who rear ends you, you may think otherwise.
you're damned if you do, damned if you don't.
Old 03-11-2007, 09:51 PM   #36
spdrcr29
spdrcr29's Avatar
Since when are plugs not safe?
If you throw out a tire just becouse it has a plug in it... You can throw them my way.
Plugs in cycle tires are unsafe because as the bike leans, it can cause the plug to "squirm" out due to the contact patch shifting. I don't actually throw out the car/truck tires that I've plugged, but I do break them off the rim and put a patch in soon after the tire was initially plugged. A patch won't pull or back out, and now they have patch plugs that are supposed to keep contaminants from getting in between plies/belts/rubber and screwing up the tire in the long term.
spdrcr29 is offline   Reply With Quote
Old 03-11-2007, 09:56 PM   #37
Longhorn Man
I've honestly had more problems with patches over the years than plugs. I think I've had maybe one plug fail.
At work, we won't even consider a patch. The boss man goes nuts when you start talking about patches.
Old 03-11-2007, 10:01 PM   #38
67ChevyRedneck
67ChevyRedneck's Avatar
Don't have a jack or a spare.... or even a garage.... The only blowout I've ever had was on a set of 15 year old dry rotted tires on an 86 camaro. Everything else has been slow leaks I was able to plug. I keep a can of fix a flat, plugs, and a portable air thingy in the truck when I go on a trip.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-11-2007, 10:03 PM   #39
67ChevyRedneck
The back tire on my Z71 has THREE plugs in it. I have to go to construction sites and I get all sorts of nails and screws in tires. The plugs have about 30K on them, at least the "oldest" one does. Doesn't leak at all, well no more than tires normally loose a little air over a few months. Just a couple psi or so.
Jesse James
Project "On a Dime"
