#26 |
Hot Rods For Life
Re: lwb to swb frame chop many pics
Looks very good. Show us pics when you get the plates in.
#27 |
Blank
anyone ever make a short long bed, something inbetween the two that you'd have to look twice to notice??
![]() 1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi. 1977 Corvette 350-375hp 4speed, silver show car. 2002 S10 xtreme, work truck 2004.5 VW jetta GLI 1.8T 6speed, weekend warrior. 2013 Audi A3 TDI, the wife's car |
#28 |
a 7ft bed that would be different.it might not be too bad cut mabe 6" out of the front and 6" out of the back. some one should photo shop that.
#29 |
Finally got this thing back to what it looked like before I got a wild hair and decided to chop it in half. Here are some more pics.
#30 |
2 more
#31 |
Hey that turned out nice. I like it. Did you bolt in the braces from Early Classic?
#32 |
I did bolt in the braces from ece. My only complaint from the braces is the first set was 3/16" to wide to fit in the channel and the second set was a little snug so I had to do a little grinding on them also. This thing seems very strong now though.
#33 | |
![]() Then I finished the short bed conversion. ![]() Kevin LFD Inc. |
#34 |
GEARHEAD
Ram-Man you do amazing work. Thanks for the progression pic's. Every thing looks awesome. yours too Kevin. RJ22
#35 |
how much do you does anybody think a a shop would charge for something like this ?another question would a shortbed bed fit right in or would it take alot modifying
#36 |
I think I saw a post where someone spent $500 to have this done when it was a rolling frame. Alot of factors come in on the price though. Is the truck complete or tore apart? If its complete alot would have to be done like shorten brake lines, fuel line, drive shaft, etc. This still needs to be done but when it is a frame off project it is alot easier. Another thought would be to find a shop that specializes in custom work alot of shops might run from work were the thought of cutting the frame in half is involved. Once it is shortened and a couple of cab mounts moved a short bed should bolt right on "famous last words". I will be going the "bed in a box" route. Not many clean short bed donors around here.
#37 |
![]() Join Date: Aug 2005
Looks too easy
![]() Last edited by Frizzle Fry; 04-04-2007 at 02:04 PM. |
#38 |
Nice job on your frame, now I am jealous
#39 |
![]() Join Date: Apr 2005
Hey guys, sorry to bring up an older thread, but I have a quick question. I started building my 67 Crew Cab frame this weekend using this post and several others (ROKCRLN) as quidance. I basically took 2 frames (the front of a LWB/and the rear of a SWB) and cut it so I had an extra 33" between the cab mounts when I was done. I've got everything done but the installation of the ECE strengthening plates. The question I have is in regard to adding radiuses to the outside edges of the ECE stiffining plates. Would this maintain the strength/rigidity but add a bit of flexibility? I've read that these plates can cause weakenesses to the frame because they are too rigid. Maybe there's a good reason for not doing it, but I thought I would ask. Here are some pics of what I'm talking about plus some pictures of the CrewCab frame.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-04-2008 at 01:56 AM. |
#40 |
That is why I did not use the C plates but flat fish plates instead. I think you are fine both ways so it comes down to personal opinion. If you are real good at welding (I am a cert welder for over 17yrs now) and trust your self that a flat plate done right is fine. If you are decent to OK at welding I would go for the C plates.
So is that your home shop or? Kevin LFD Inc. |
#41 | |
![]() R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-22-2007 at 12:36 AM. |
#42 |
