#26 | |
Used Register
Re: Welder Opinions Wanted
All excellent points! Thanks I have a bit of an advantage as I already have a Miller Thunderbolt 225 AC/DC stick machine and, therfore, all of the paraphenalia associated with welding (gloves, AD hood, etc.). I also have a TIG (heli-arc) torch attachment for the crackerbox welder and the stuff to go with it (flowmeter, bottle of Argon, account at local welder's supply, etc.), so I'm not starting from scratch....get it - arc joke ![]() The machine size is solid in my mind - a 110V unit will be too small for me and a 250 A machine on running gear is out of my budget. I have the provisions for power (I do electrical work, among other things), so that will not be an issue. I did read through the referenced thread, but didn't really find the info I am looking for (mostly looking for "user reviews" of these machines). Some of the links have provided me with good info and hopping from those links have as well. Based on my research so far, I am leaning stongly toward the Hobart 187. We have 6 local supply places in town - Praxair, Airgas, AOC, Mathess and a couple others, so local support of any of the big 3 should be OK. I have a hard time paying $150 more for the same machine to "buy into" my local support. If my consumables bussiness is not enough for them, I find another place. Herb |
#27 |
Weekend Warrior
[QUOTE=metalmassfab;2084284]much less splatter than the 175, and 251 - nill on the splatter. QUOTE]
![]() ![]() I don't understand. Shouldn't make a differance if the machine is 115 or 230
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
#28 |
Questionable
Herb, I will say this: I have very little MIG experience, but I was overjoyed to see what my Lincoln 175 would do. I probably sat in one small area too long (2-3 seconds), and it literally melted a section the size of a quarter in the bed frame I was working on - fortunately this worked in my favor. This was on roughly 1/8" thick steel I am very confident that this thing could do a number on a truck frame - and I am using mig with solid wire, not flux core. I think the inside of the box says to use flux core if you're doing anything over 3/8" but I am still needing to look at the chart to know what to use.
I am a super newbie when it comes to welding though, so ... obviously I wouldn't rely on anything I said - I can only share my experience, and everything I've typed in here so far has been my experience ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#29 |
I say miller axcess 450... HAHA 10 grand.
that is what i use at work everyday, i weld half inch plate almost every day and i was welding 3mm(1/8") material today. go big if you can. when i get myself a welder in the next year or so, it will be a miller 251 or if i think i can swing it a miller 350 CC/CV. the 350 is a power unit that can supply for TIG MIG stick air-arc and flux core. besides being 4 machines in one, it has pulsed mig capbility, which is nice. or a miller 350p which is rated for 22 gauge through 1/2 single pass, you can also get a push pull gun for it so you can use a roll of aluminum wire instead of a spool gun ryan Last edited by ryanroo; 03-20-2007 at 08:53 PM. |
#30 |
Used Register
Pulling it back down to the realm of reality....
I ordered the HH187 tonight - less that $675 shipped and I'll have it next week. Can't get to a point to use it until well after that anyway. Herb |
#31 |
Good choice. I got the HH180 a couple years ago. It's a great machine. I've had no problems with it at all. I've mostly been working with 1/8 to 1/4 steel.
#32 |
Keepin an eye out
I have a HTP 200 I still havent even tried.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#33 | |
Junior Member
[QUOTE=arkracing;2085326]
![]() I know, sounds like liar material ![]()
Ryan Metal Massacre Fabrication New Projects: -New radiator core supports, steel and stainless -Aluminum radiators -Aluminum dual electric fan shrouds '69 C-20 Custom '69 Nova...BIG BBC soon '72 3-door 'Burb...in a few '94 K2500 454 'Burb |
#34 |
Junior Member
[QUOTE=arkracing;2085326]It makes all the difference in the world. Using a 115V machine adds convenience since you can plug it in anywhere. Unfortunately, a 115V machine is limited on how thick you can weld. I have a Lincoln SP135 and I love it. It is 115V and so far has done everything I have asked it to do. I also have a Lincoln PrecisionTIG185 and since it is 220V it takes up where the SP135 left off. TIG is definately a great way to weld but sometimes it is not practical to weld with since it has a foot pedal current control. My skill level is also not so good on vertical welds with it. One of the advantages of buying a Lincoln SP135 is all of the consumables, tips, and torch supplies are available at LOWES. Having a local welding store is great but their prices are usually high and my local AIRGAS store isn't open on Sundays.
#35 | |
Weekend Warrior
[QUOTE=jodydewey;2086418]
![]() He said that he gets less spatter with a 115 machine vs. a 230 machine - should really make a differance.
#36 |
Used Register
It's here! It's here! It's here! It's here! It's here! It's here! It's here! It's here! It's here! It's here! It's here! It's here! It's here! It's here! It's here! It's here!
Yea! ![]() Now to get a bottle and try it out! I went to Cyberweld for it and they had it backordered, but it showed up today. Herb |
#37 | |
Junior Member
#38 |
Chief Honcho In Charge
OK...so went to my first welding class last evening.
I really like the pulsed welding....I think he called it spray mig welding...man it was smooth. Of course it was 208V.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
#39 | |
Used Register
Then fix the Willys clutch cross-shaft, then steps/sliders for the Blazer, then body panel learning on the Scout, then more practice on the Willys body, then bumpers for the Blazer, then bumpers for my son's Jeep, then more bodywork on the Blazer.... And then in May..... ![]() Herb |
#40 |
I'm buying a Miller 210 as soon as funds are available.
Alex 1971 Lil' Red 350 SBC 700R4 |
#41 |
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#42 |
Yep yep yep....I did a lot or research and reading...I think it will do just about everything I need for this 67-72 truck building dieseze I seemed to have been aflicked with!
#43 |
What is the best mig for under 500.00 bucks
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
#44 |
I am looking at a Lincoln 175T and a 180C I just like the price of the 175 better
#45 |
23 years as head fabricator in winston cup says LINCOLN!! RED!! NOT BLUE!!
#46 |
Active Member
I bought a lincoln Weld pack 155 several years ago and its still new in the box this will be my first time using it hopefully it will take care of my welding needs for now. 230V
#47 | |
Used Register
Herb |
#48 |
The new MILLER's have a micro-switch in the trigger which WILL give you trouble if you use it everyday!! Better order a spare! Lincoln uses a simple contact that's trouble free.
