04-11-2007, 04:33 PM | #26 |
Re: I coulda had a Dana 60!
Damn!!!!!
Yer moving faster than me... I have to find the camera to share pics but I have my K5 practically laying on the garage floor removing my D44/D60 combo to install D60/14FFd combo Por-15 looks and works great: here is the inside of my hood in Por-15 You can see it bubble into the heavy rust as it drys
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
04-12-2007, 04:12 PM | #27 |
Sofa King. We, Todd, Ed.
Axles are done! New HD Spicer joints and a fresh coat of POR-15.
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
04-17-2007, 11:26 AM | #28 |
Almost done. Just needs calipers, weld up the shock mounts and install it! One snag is the PO didnt have the u-bolt plates...guess Im gonna have to make my own. Another snag is MY NEW PROJECT...59 Belair!!!!!
04-17-2007, 11:35 AM | #29 |
Page intentionally left blank.
Quick Robin, to the Batmobile!
I had a friend in HS who's dad was into the '59's, had about 3 of them. It's a car that's so quirky to be cool. Myself, I want a '58 Del Ray... saw one once, and wanted it since.
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams '67 GMC 4x4, 305 V6! Or all the parts for anyway... '17 Subaru Outback. '18 Toyota Tacoma TRD Off Road. '99 Ducati 900SS. |
04-17-2007, 01:00 PM | #30 |
Post Whore
Johnnywagon - when you get the Dana 60 install be sure to post what you did in relation to the front rubber brake lines. I think the hard line fitting may be different than what is needed on the Dana 60's rubber brake lines and would like to know if that is correct. Axle's looking great btw.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
04-17-2007, 02:34 PM | #31 |
Yea, I can see that there is an issue w/the brake lines. I already have the nice, expensive braided 6" lift brake lines from Skyjacker and thier catalog shows different part numbers for one ton trucks. Im think Im gonna have extention adaptors made at the local hose shop to connect the one ton calipers to my 3/4 ton brake lines. I've ordered in some one ton lines just to see but.....well, we'll just have to see. I'll keep ya posted.
04-17-2007, 10:55 PM | #32 |
what is the difference exactly between 1 ton & 3/4 ton brake lines?
04-18-2007, 03:54 PM | #33 |
Well, this is what I've figured out...so far. For starters there are different calipers on some one tons. I have the really big single piston type, so I cant speak for what works on the other stuff.
My Skyjacker (#FBL18) 6-8" lift stainless brake lines (that are on my 3/4 ton D-44) will work on the D-60...kinda. They attatch to the caliper just fine. The issue MIGHT be that they now come out at a 90 degree angle rather than straight up. This might cause interference and will effectively shorten the brake hose. I havent found a 90 degree adaptor yet, but Im off the the specialty hose shop later.
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon Last edited by johnnywagon; 04-18-2007 at 03:55 PM. |
04-18-2007, 04:35 PM | #34 |
I looked at my dana 60 calipers and they sound like the ones you described.
04-18-2007, 06:44 PM | #35 |
You know...since you have a dana 60 now your title should say "I bought a Dana 60!" ....hey,I can fix that,if you want...
04-18-2007, 06:48 PM | #36 |
If you can change it that would be great. Thanks!
04-18-2007, 06:54 PM | #37 |
Re: I bought a Dana 60!
The deed is done.
04-19-2007, 02:37 PM | #38 |
One thing leads to another....so this 59 Belair project just fell in my lap. Way too good a deal to pass up. The plan is low buck summer time rat rod, but NOT untill I get the D60 in the Blazer. The problem is as we unloaded it off the trailer the brakes locked up. After a little investigating, 3 stuck wheel cylinders...its been in a field for over a decade w/a dead 6 cyl.
I got one drum off the back...needs shoes, of course. The other rear drum is stuck on, broken adjuster. Any tips on how to pull it off because I gotta get this damn thing rolling so I can get back to the Blazer! I havent even got to the front drums yet! AND yes I know my Chevy collection is way to big for my lil one car garage. Not shown in these pix are two 65 Chevelle wagons and a 71 1 Ton Camper Van.
04-24-2007, 11:56 AM | #39 |
OK, the brake job on the 59 is done. Its now mobile and out of the way. Back to the Blazer. Got the D44 out, now Im waiting on the D60's PO to bring me the U-bolt plates...
04-24-2007, 01:48 PM | #40 |
COOL!
Your one step ahead of me..I hope to pick up my axels on Friday. Pacific Fab in MorganHill are installing the 4:56R&Ps for me and recentering some H1wheels too. Hope all is ready by Friday then I can share some pics with ya'all Got the inside cleaned up a bit: Anyway I'll stop highjacking your thread hehehehee
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks Last edited by Burt4x4; 04-24-2007 at 01:50 PM. |
04-30-2007, 10:51 AM | #41 |
I'm trying to catch up too you Johnny
Got one of the wheels painted. PacFab did an AWESOME job on these H1s. D60 is under the front now: The 14FF needs to have the perches relocated. I have the welds mostly ground off, another 20min or so and they will pop off. THe other H1s are ready for paint too... I need hardware now.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks Last edited by Burt4x4; 04-30-2007 at 10:52 AM. |
04-30-2007, 12:53 PM | #42 |
Post Whore
Great progress Burt!
04-30-2007, 03:34 PM | #43 |
Burt, those wheels look sweet!!! I'm still waiting on the damn u-bolt plates.
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon Last edited by johnnywagon; 04-30-2007 at 03:35 PM. |
04-30-2007, 03:42 PM | #44 |
Cool thanks bro!
Ya I have to find rear plates & ubolts too....I guess gravitiy won't hold it togeather
05-01-2007, 01:17 PM | #45 |
FINALLY!! The front u-bolt spring plates were delivered (late) last night. Complete with factory sway bar, half torched off u-bolts and years of fine Alaskan rust. I got em cleaned up and coated w/POR-15 so hopefully everything is down hill from here. I did get some finished pix of my home made front shock mounts.
.........."if its worth doing, its worth OVER-doing:.....
05-01-2007, 06:53 PM | #46 |
??? Should I use anti-sieze on the big studs that screw into the carrier (rather than a u-bolt on D60's) or what??
05-02-2007, 11:54 AM | #47 |
Post Whore
Beefy looking shock mount!
05-02-2007, 01:12 PM | #48 |
I hear the best thing for thoes two bolts is to tossum out and install threaded studs and then secure the spring plate with nuts instead of bolts. I have to find out myself what the best way to do that is and if anyone sells a "stud kit". My buddy Ryan did this after his two bolts sheared off one summer
05-02-2007, 03:11 PM | #49 |
To simplify things I ordered a u-bolt kit from Skyjacker. It came with studs!
05-02-2007, 03:45 PM | #50 |
Weekend Warrior
Dumb question - do you have to move the spring perches on the D60 to put it in? I'm assuming No since the pass side mounts right to the center section - but was just wondering.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
