Old 04-14-2007, 05:37 PM   #1
marvxyz1
marvxyz1's Avatar
Re: Ooooooohhhhhhhhh My God!
You definitely have coolant in your oil!!!!
marvxyz1 is offline   Reply With Quote
Old 04-14-2007, 05:35 PM   #2
marvxyz1
marvxyz1's Avatar
You've definitely have coolant in your oil!!!!
Old 04-14-2007, 05:46 PM   #3
Low84
Low84's Avatar
So what exactly does that mean? How does that happen, cracked head? What effect does this have on the engine?
Is it a gonner?
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 04-14-2007, 05:58 PM   #4
SCOTI
SCOTI's Avatar
It means either the head has a crack or the head gasket is blown. Pull the head & look @ the head gasket between each cylinder. If there's any area that looks like the material has been breached, that's your answer. No breaches.... have the heads checked @ a local shop.
For what it's worth..... If your going to do it, do it right. Pull both heads & replace both head gaskets @ the same time. If you can, get the heads 'rebuilt' or replace them w/the Vortec kit you mentioned earlier.
The residue that was on your finger does look suspect. If it's light in color, chances are it's a blown head gasket.
You need to see if there's coolant in any one of the cylinders. Too much coolant & the cylinder will 'hydraulic', which means it won't compress the combustion mixture as intended & can bend valves, rods, or do other general damage.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-15-2007, 02:25 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
Now the question is...how long was it run like this?
Pyrotechnic is offline   Reply With Quote
Old 04-15-2007, 02:46 PM   #6
BaddBusa2005
BaddBusa2005's Avatar
damn man, doesnt look so good. Good luck with the vortec stuff, should wake the truck up pretty good. How about a little clean up in the engine bay
I have a set of long tubes you could put on that thing too if you are interested. I took them off when I did the 5.3 swap in my truck.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
