#26 | |
Re: Lowering a 1957 GMC 3/4 ton
thank you for the information of this. can i put the same Shackle kit? Ok maybe the shock absorber i must exchange.. have you pics for me ? ![]() Thx F.S
54NLOW |
#27 |
polishing a turd
you will need shorter shocks. you could use the stock shackles (i think). most of the work will be in correcting steering geometry.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
#28 |
In doing the spring flip on the front suspension, you will somehow have to address the fact that the axle has a mounting surface ony on the top, where the springs are in the stock location. The bottom is only skinny I beam. Maybe some good welding will help. If anyone has done this, I'd like to know how, because nobody makes a 3/4 ton drop axle. bummer. Should I just find a 1/2 ton before I spend any money in the 3/4 ton? I just got it and have spent (traded) a 77 chevy and 300 dollars on it. someone out there will trade me for a first series 1/2 ton!
#29 |
polishing a turd
you could just use 1/2 ton axles under your truck...then you can bolt on discs too.
#30 |
polishing a turd
there is some info in the second half of this thread that i just found:
http://www.stovebolt.com/bboard/cgi-...=001233#000011
